Old 10-06-2009, 05:21 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Originally Posted by camelll View Post
Your getting more warm air into the engine with the stock box, you are getting more cold air with a cai, cold air is denser than warm air.
And how does that make the exhaust gas more polluting? You still haven't explained that!
More air means more exhaust. Duh, of course!!! So does more driving. I still don't see the point.
If, say, 20% of the exhaust are emissions, if you put more air in, you'll get more exhaust, but still, only 20% of that will be emissions. So how is that worse?
Smog measures the percentage of pollutants in the exhaust gas and so far nobody has shown that more air in the engine increases the percentage of pollutants. You've only said that more air in equals more exhaust, to which I say: DUH!
fmicle is offline
Old 10-06-2009, 05:35 PM   #2
camelll
Drives: 07 sedan
You are saying it yourself, that the air intake can affect emissions. What more can I say.
camelll is offline
Old 10-06-2009, 05:40 PM   #3
fmicle
fmicle's Avatar
How old are you?
fmicle is offline
Old 10-06-2009, 06:14 PM   #4
camelll
Drives: 07 sedan
Do you understand the concepts of "absolute" and "relative"?
20% of 100 is the same as 20% of 1,000,000 in "relative" terms. THE SAME. That's how smog is measured in percentage!!!
Yes, I am putting out more exhaust, but it doesn't have a higher percentage of pollutants, it's the same percentage!
A CAI is causing more emissions the same way driving more causes more emissions. Someone driving 100 miles will cause double the pollution of someone driving 50 miles. Simple enough for you? According to your logic the first guy should not pass the smog
To say that 20 percent of 100 is the same as 20 percent of a million is silly, 20 pph is different than 20 ppm. You will not pass if you are putting out 20 pph but you may pass with 20 ppm. I don't live in California and cannot tell you how they do smog test. What is the baseline and what percentage do you need to pass? To say that burning more fuel does not equate to more emissions or noxious gas is silly.
How old are you?
HA HA enough to know that burning more fuel makes more emissions.
camelll is offline
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
MY new PRM Intake... marcus Performance Modifications 27 05-03-2009 11:04 PM
Bomz Ebay Intake - Partial Review Split Performance Modifications 11 11-19-2008 02:12 AM
