Old 10-11-2009, 09:59 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
10KW is a litttttle bit rough.
figure the car will use 25amps for typical car stuff so im working with maybe 270 amps
270 Amps x 14 Volts = 3780 usable watts (assuming your yaris sustains 14v typically)
Whats more important is the idling, I should get around 140-150 amps at idle but we'll see. Im the worst skeptic
PG TLD22 8V Line Driver
Old 10-12-2009, 11:18 AM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if you're a skeptic... then change your equation.. 270*13 = 3510
when you have a bass hit, it's not uncommon for your voltage to sag 1volt, also... that alt will charge your system quickly... depending on how he makes the voltage regulator, the voltage may drop down quickly to the mid to high 13's.
The Big One upgrade fuji DIY / Maintenance / Service 2 02-15-2009 02:37 AM
N/A stage 1 upgrade? forpinks Performance Modifications 12 03-18-2007 08:42 PM
