Old 10-17-2009, 03:03 PM   #1
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Originally Posted by ROCKLAND TOYOTA View Post
YOUR 2009 doesn't have TPMS? Also if the tires were set to that 27 psi your light would have been on.....
Don't know if I have the tire pressure monitoring or not. I didn't specifically ask for it, so unless it is standard, I don't have it.
There was no warning light. Don't those sensors look for DIFFERENCES in tire pressure among the four tires, rather than look for some specific minimum pressure threshold? The tires were very uniform in pressure when I checked them this morning. They were all kind of in between the 26 psi mark and the 27 psi mark. That's what makes me think they were set that way.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 10-17-2009, 10:55 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
They measure "gauge pressure" in each tire. I think they go off when the pressure drops below 24 PSI, which is down 25% from the recommended 32 PSI. The Yaris has a basic TPMS system that can't tell you which tire(s) went down, only that one or more is low.
Old 10-26-2009, 09:30 AM   #3
H3LlIoN
Drives: '09 Yarrrr hatch
Tom
If it's a USDM, then it has TPMS. (TPMS became mandatory in 08)
The Yaris TPMS is set to go off at 28/29 psi.
This info is as provided by my roomate, who is a Toyota/MCEP certified master mechanic, currently employed with Toyota.
H3LlIoN is offline   Reply With Quote
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
