Old 10-17-2009, 04:32 PM   #1
sıɹɐʎ
Economist
sıɹɐʎ's Avatar
Drives: 2007 Yaris Lifback
I have a head unit with rear USB input. I ran a USB extension cable to the center console and dremeled out a hole in one of the accessory covers to place the female end of the extension cable. I super-glued the extension cord in and then used high-temp hot glue for support. I think it turned out well; it works perfectly, and is tug resistant.
Like you, I also considered the pop-out piece next to the lighter jack, but it's part of the center console, and, aside from gluing it back in, you can't replace it individually. I chose to make my own using an accessory panel cover because they can be replaced for just $5 USD. If you're looking for something with more of an OEM style, IsLNdbOi suggested this on another thread.
sıɹɐʎ is offline   Reply With Quote
Old 04-19-2011, 03:41 AM   #2
tmalecu
Drives: Yaris sol
USB port on yaris
Hi, how do you made this? Do you follow some schematic procedure? If you are so kind to give it to me by prive messages I will be very happy.
Thank you.
tmalecu is offline   Reply With Quote
