Old 10-18-2009, 07:44 AM   #1
nemelek
DWEED
nemelek's Avatar
Originally Posted by AbsolutelyRed View Post
I have confirmed at least 5 or 6 times now that 3.9 quarts is correct. There's no way I can figure out that 3.5 quarts would be enough oil for a full fill (assuming a complete drain and a new filter, and an accurate level reading).
AR
Just did my oil change 2 days ago. Went and checked the level while reading this post and the 3.9 quarts of oil I put in put the oil level right at the top mark.
Old 10-18-2009, 10:06 AM   #2
posaunemeister
Drives: 2008 Yaris S LB - MM
Yeah, I went back and checked my oil level after adding those 4qts and I was barely beyond the max fill level. So I drained some of it yesterday evening. I'm going to check the level right now, as the car has been sitting outside in the cold all night long.
posaunemeister is offline   Reply With Quote
Old 10-18-2009, 05:16 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Same here. No way I'm going to drain it, as it's not hurting a thing. And no way am I going to try to measure and subtract 0.10 quart when filling my engine. I'll put in 4 and drive off happily. Putting in another whole quart would doubtless cause problems with oil splashing, aerating, excessive oil consumption through the PCV system, etc., but an overfill of 2.5% isn't worth obsessing over. Completely negligible.
Old 10-18-2009, 06:00 PM   #4
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
The way I heard it, what happens when you put 'way too much oil in an engine is that the crankshaft counterweights and the big ends of the connecting rods hit the oil and beat it into a froth. Enough of that and the oil pump starts sucking air. Since air is compressible, unlike oil, this can cause an air lock, and goodbye bearings! OP is lucky if no damage was done.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 10-18-2009, 11:21 PM   #5
Yaris Hilton
Smile
Exactly right. My point is that 4 quarts isn't "way too much oil." Toyota's engineers are competent enough not to put their recommended fill level right on the brink of disaster. There's a considerable margin for error.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
