2008 Prht Miata Red
Drives: 2009 3D 4AM PWR Pkg, Yel Jolt Join Date: Feb 2009
Stock intake modification
Anyone try to modify the stock intake box with any success?
I noticed a heavy screen inside the stock intake, I removed it on another car I had and had more flow with a stock element. I could feel a diffence with the other car I did this to. Note: that steel screen is a fire screen and provides protection. with that said people that put a CAI on their car no longer have the screen. and maybe ducting (alum./stainless tubing, for heating/aircond. or oven ducting) over your intake end to the front of the car like the the one at Lowes/Home depot to match the intake snokel diameter with a hose clamp It is a low dollar with the ducting or no dollar fix fix just removing the metal screen, But I have not tried it on mine. I am wondering if anyone else has done this with success? Westgl |
I think some people did this, the posts would be pretty old now though. Ducting from the outside will definitely force more air through the intake if it's done right.
![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
look up blacksandygovitz, i think thats his screen name, he had a pretty rad set up using a stock air box.
Two Yari on home! ![]() |
#4 | |
Learn to Relax
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you can cut anything that's not structural for the airbox.
i'd stay away from corners, and brackets or bushing areas. take a hole-saw or jig to it...dremel, cutoff wheel, grinder, whatever. i personally dont think it's worth it. you can pick up a 3" pvc pipe, a few elbows and a 3" filter for under 25 bux, and a can of krylon for 99c |
I tried to find Sandies old picture, but he has upgraded since then. He basically dremmeled the entire top plate so that the filter was exposed but still secured. Try PMing him he might still have the picture for reference.
i'd modified my original box, with satisfaction
http://www.yarisworld.com/forums/ima...28Small%29.JPG added a sporting filter removed the original tube and added a big size tube taking fresh air rear the left headlight. i feel improved hp |
#8 | |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Imo i think the car ran better with this set-up than with my current aem w/ fujita5 filter probaly the low end torque ??? |
#9 | |
ドン フアン
DAMN!!! Love the CF in your engine!! Looks damn hot!
I always thought that set up was pretty bad ass.
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
i'll probably wait until i get my C-one replica front bumper and do a small duct to the air box from the slit in the bumper :)
Sold the yaris... rocking an 89 vw cabriolet now :) |
![]() ![]() Drives: 2008 Yaris S LB - MM Join Date: Aug 2009
For my stock airbox, I did a few steps:
1. Used a dremel to cut out the mesh filter padding that is located in the top part of the airbox, and then blew out all of the residual particles with pressurized air. 2. Replaced the stock filter with a K&N replacement. 3. Opened up the driver-side fog light cover and covered it with 3 layers of screen mesh (to keep dust and debris from entering the engine bay). 4. Hacked off half of the bottom part of the snorkel, rotated it 180 degrees so that it points downward, and then attached a series of PVC piping that leads to the back of the fog light cover, so that my forward motion will aid the intake process. I superglued the snorkel into place, the PVC piping is secured by rubber couplers and the wide-mouth PVC coupler that leads into the fog light is secured by several plastic fasteners. I've noticed a very big improvement in terms of throttle response and acceleration, especially as the weather chills up more and more. Obviously, I get the best results at night. The only downside is that I get a little worried anytime I have to drive over 40mph in the rain...
#13 | ||
I still have my stock airbox... only out of necessity though. I have a scion supercharger intake pipe which means it did not line up with the yaris' stock airbox, but not to worry, with it upside down and cut away it works just fine - actually it looks a lot like the black yaris pictured already
Morgan got any pictures of your engine bay, I wouldn't mind seeing a supercharger with a stock airbox.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
blacksandiegovitz - Thanks for the inspiration, just took your mod (pictured above) with my instake and my afe pro-dry filter, sounds kool, works great.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
a pic:
| The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-06-2009 11:37 PM |
| TRD Cold Air Intake IN STOCK!! | Sparks Toyota-TRD | Sparks Toyota | 2 | 05-11-2009 04:03 PM |
| Stock Intake Manifold | gwasabi | Willing to Buy by private party | 0 | 05-04-2009 05:32 PM |
| WTB: Stock intake rubber tubing | spkrman | Items for Sale by private party | 8 | 02-04-2007 11:09 PM |
