Old 10-19-2009, 06:01 PM   #1
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Originally Posted by talnlnky View Post
...for reducing noise, rca placement has very little difference... the whole car is the ground... and interference can be induced from both the positive & ground... the "ground" in a car isn't a "true" ground there is still voltage and amperage passing through it... its not like a 3 prong plug in a wall outlet which has a pos/neg/gnd. Cars are actually more like pos/neg (ground is kind of a misnomer)...
Actually you are wrong. In your home the 3-prong outlets are POSTIVE/NEUTRAL/GROUND with the larger slot being NEUTRAL. NEUTRAL and GROUND are actually both connected to ground. This is a safety feature that allows a short to the casing of whatever is being powered to trip the breaker.
In a DC system (like a car stereo) ground always has current flowing through it as long as there is a path to the positive power source. In a car most people call it GROUND when referring chassis metal in a negatively grounded electrical system.
Some people advise against routing your RCA cables next to your power cables because the high current the power cables pass may be enough to induce a voltage into the RCA cables which would appear as noise.
RUFFSTUFF is offline   Reply With Quote
Old 10-20-2009, 05:02 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thank you for proving my point... power still flowing through the chasis... still a good amount of power (about 20-50% more power than over the power cable in fact depending on what kind of amp you run). And noise being induced into the signal via RCA's is still one of the least common reasons for noise in the system. So even if placing your cables did make any kind of a difference.... IT STILL WOULDN'T MATTER 99.9% of the time cause its all about bad electrical connections and voltage differentials.
2007 Toyota Yaris Hatchback - 5-Speed Manual truebreakerz Cars for Sale by private party 23 09-17-2009 09:29 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-02-2009 11:04 PM
Put a yaris sedan front on a yaris hatchback?? pp.sweet Cosmetic Modifications (Exterior/Interior) 24 08-21-2007 10:17 PM
