Old 10-20-2009, 12:43 AM   #1
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Originally Posted by ellenbetty View Post
With winter coming, and the batteries ending up dead in less than a week, I will have to go out and start each Yaris every other day for at least a 1/2 hour to keep the battery charged. Other wise the dead batteries will freeze. Since it is unsafe to charge a frozen dead battery, I will have to make sure that the batteries do not go dead during this winter.
I'm telling ya... just letting the car idle won't do much for you if the batteries are already having issues. Alternator output (current) at idle can be as low as 10 amps and will increase with rpm. Just idling your car puts the output of your alternator just above "self-sustaining," there will probably not be enough overhead to get a decent charge on your battery. I believe your research to be incorrect. A 1/2 of driving may show some improvement... a 1/2 hour of idling probably not.
You can check this out:
http://www.edmunds.com/ownership/tec...5/article.html
RUFFSTUFF is offline   Reply With Quote
Old 10-20-2009, 02:35 AM   #2
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
I tried that link. it does not work.
ellenbetty is offline   Reply With Quote
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Did you order fog lamps? Driver New YARIS Purchase Forum 27 11-29-2006 06:27 PM
Where to find Yellow capsules for fog lamps? W.A.S.P Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 01:01 AM
