Old 10-20-2009, 05:17 PM   #1
you said this:
100 degree F gasoline provides more power to the motor than 20 degree F gasoline.
Sorry but you are wrong there and in post 104:
I think you are mistaking the cause of the additional power. Modern cars have sensors that detects the temperature of the gasoline air mix. The car's computer analyzes different sensors to decide the optimal amount of fuel to inject into the motor. More fuel is injected when the air fuel mix temperature is low to aid combustion to provide the additional energy needed to heat all of the fuel air mix for additional production of hp to keep the motor running.
It's just not so. Sorry. I won't post about it again, this thread was about your batteries, as you said.
Old 10-20-2009, 07:28 PM   #2
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
you said this:
That was just her way of describing how an oxygen sensor or something sensor works... somewhere someday she may be right.
Ellenbetty, you are putting alot of effort into avoiding the obvious. Here's what I see...
1. You installed 2 fog lamp kits because you hate cars without fog lights but you bought 2 used cars without fog lights.
2. Something in both kits is not wired properly but you're not really interested in that.
3. Your batteries are draining and it's getting chilly.
4. You should never ever touch silicone caulk again. If you do, don't take pictures.
5. You don't want to drive your cars because you are afraid of getting sick from zombies.
6. You enjoy some alone time sitting in your car at idle for hours at end.
7. You think jumpstart power packs are magic boxes.
8. You think your car has a gas temp sensor.
9. Did I miss anything?
RUFFSTUFF is offline   Reply With Quote
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Did you order fog lamps? Driver New YARIS Purchase Forum 27 11-29-2006 06:27 PM
Where to find Yellow capsules for fog lamps? W.A.S.P Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 01:01 AM
