Old 10-22-2009, 01:21 PM   #1
Antipilor
Drives: 2008 Yaris 5-speed
So I think I might have screwed up somewhere, I just notice in the last day or so after I installed this mod (stills not working but I havn't had time to track down the problem). I noticed that the airbag off light on the passenger side will light up only for a bit randomly while driving. The airbag on light works fine when someone is riding with me. Any ideas on what I did wrong?
Antipilor is offline   Reply With Quote
Old 10-22-2009, 01:32 PM   #2
The two are probably unrelated. The airbag light occasionally flickering may be due to the empty seat weight calibration being off.
For the cruise issue, start with your connection at the ECM. Make sure you are in the correct pin there. If you just want to verify that the cruise and airbag issues are unrelated, disconnect the cruise wire to the ECM.
Posting pictures of your connection to the ECM and you resistor setup/wiring to it will help as well.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
