Old 10-22-2009, 04:20 PM   #1
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Originally Posted by IllusionX View Post
Can't you put it in neutral and use dingy towing?
I say the reason the put it in the manual that you should NOT tow the auto yaris front wheel on the road, they don't want you to leave it in park and start towing it..
I say the reason the put it that way in the manual,
it that it will destroy the transmission and possibly the
electric steering motor....if you tow it like that.
but I am funny that way....
of course not park (you'd have to be seriouly retarded to try to tow
in park),
neutral...whatever. the transmission will NOT handle it.
127.0.0.1 is offline   Reply With Quote
Old 10-22-2009, 10:04 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
in park),
well, the thing is.. neutral in an automatic is the same thing as neutral in a manual transmission.. it runs freely.
The thing with the user manual, i believe their think we're dumb enough to leave it on park..
Old 10-22-2009, 10:34 PM   #3
toast
Drives: 2007 LB
Not exactly. Automatics have a viscous fluid connection between driveshaft and engine that requires trans fluid to be circulating for lubrication and cooling. So if your engine is off and you are in neutral and rolling, you are going to evenually burn up your trans and have a problem.
When the manual yaris is in neutral there is no direct connection you are good to go.
toast is offline   Reply With Quote
Towing a trailer, anyone? fmicle General Yaris / Vitz Discussion 52 02-17-2010 06:02 PM
FS: Towing Kit dwnhillskater Items for Sale by private party 3 08-04-2009 12:55 PM
Towing churp General Yaris / Vitz Discussion 21 01-26-2009 10:28 AM
The Yaris, Cultures, Towing, and Customer Service jderrick General Yaris / Vitz Discussion 2 10-28-2008 07:08 AM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 07:07 PM
