Old 12-06-2006, 12:48 AM   #1
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
There is a big difference between LB and Sedan, the Sedans use standard LED backlit gauges like the celica, the LB's use Optitron, which, as I understand, is high contrast white LED's behind layers of colored and smoked acryllic. As for the Digital readouts... you might try disassembling your cluster and attaching colored celophane paper to the segment LEDs underneath, this is what i30 and Maxima people do to change the digital displays on thier radios, A/C's, and clocks.
paultyler_82 is offline   Reply With Quote
Old 12-06-2006, 06:21 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
well as far as the speedo-tach-and "backlighting" then the sedan is the same way, I wasnt interested in chaning the backlighting (just the gauge cluseter indicators) but, you could change all the LEDs; which include the lighting to the smoked arcyllic (it seems to use what I'm gonna call "light tubes" to lite the acryllic) if you change the "backlight color" the outcome will be a slightly darker color then what you buy; so if you get a "high intensity" LED you might be able to make up from the "smoke"
edit:
but then again the only way to know for sure is to have someone with an LB take apart their gauge cluster to see just whats there (a posted pic for verification would be flipp'n sweet)
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
DIY - How to change you stock radio color vodkalush DIY / Maintenance / Service 70 09-13-2012 10:32 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Gauge Cluster Color Changed (PIC Inside) vodkalush Cosmetic Modifications (Exterior/Interior) 11 12-04-2006 08:48 PM
Change the Console Control/Shifter Color Ayka Cosmetic Modifications (Exterior/Interior) 1 09-28-2006 11:21 AM
