#19 |
Five-Star General
hey thats a pretty cool idea actually. This wiring took a while to do... so i'm keepin it the way it is. It would also take a lot of wire and me taking apart the headliner.
#20 |
![]() ![]() Drives: AE101 Prizm('07 Yaris 3DR TBA) Join Date: Jul 2006
If you wanted to do it, you could probably get to the switch on the door jam.
#21 |
there is a domelight wire under the dash to wire to the door switch would require a relay, and the domelight wire should be tested with a multimeter before you start splicing, im not sure if its 12v
#22 |
Nice twixt
#23 |
I may try my own idea when I get my Yaris (in October
#24 | |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
should be ~12v., that's what the dome bulb is rated for, definately use a relay, you don't want to power the cathode transformer off the dome light's wire, that would probably draw too much current. |
#25 | |
#26 |
I mounted my tubes to the silver cross brace under the seat with 3M tape the underdash tubes as well, more of a floor glow than anything else. I like somewhat dimmer lighting - is it actually as bright as the photos show?
#27 |
Thanks Paul, will do. I'm gonna have a stack of parts and a long list of mods by the time I actually get the damn car.
#28 |
Five-Star General
its brighter than the photos show, i had to reduce the shutter speed so it wouldnt blur as much on the camera. I'll hook it up to a tripod tonight and take a real photo. I dont even wanna touch that relay stuff, that looks a little complicated.
#29 |
CAMRY FTW!
Drives: Camry LE V-6 (225,000+ miles) Join Date: Jul 2006
Nice mod.
I drive a Camry. I have no imagination.
#30 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
what did you use for power and did you have to buy a switch or did it come with
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#31 |
It really looks perfect. What I want to know is if there is way to wire them to the stock dome light so they will fade on when the door is opened, and concurrently wire them to a switch so you can turn them on if you're driving around and want to have them on to show off a bit... without of course having that switch also turn the dome light on. Sounds complicated.
#32 |
oznium 'thodes are the shyte... not the most durable, but they are really bright and cheap!
#33 |
looks great
My Ride From Puerto Rico Yaris Sedan 07 - MODS - 20% Tints Tanabe NF2210 Suspension Two AudioPipe 12 Inches for Bass with 1000 Watts Amp BOSS 17 Inches Rims Ground Wire
#34 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris sedan Join Date: Aug 2006
looks good
#35 |
Ordered a kit today in blue.
#36 |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
What kit?
I picked-up a dual cold cath kit from compusa for just under $20. The kit came with a switch, but I swapped it for a lighted one from AutoZone. I wish I had taken some pics of my install, it would be a crazy easy DIY write up, unless it involded hooking into the Dome Light wire and still having it "switchable"; if only i knew more about using relays....
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
| Looking for Yaris Sedan modifications! | PMCRW | New YARIS Purchase Forum | 1 | 06-15-2006 12:51 AM |
