Old 10-01-2009, 08:04 PM   #19
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Did you put back on your rubbers for the springs? What was the cost?
Old 10-01-2009, 08:29 PM   #20
kngrsll
Apexing Egg!!
kngrsll's Avatar
i paid $107 for the entire spring kit plus $20 to ship. They have used sets of springs on there all the time for $80 on FitFreak.net. I think there is a set of Tanabes right now, they are 280 lbs, so not quite as stiff, but they are lower. They may look slightly better, but i really wanted the heavier rate.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 10-02-2009, 05:43 AM   #21
regal
Drives: 09 Yaris 3 Dr White LB
Be careful folks, the shocks available for the Yaris can't handle high spring rates. Look for blow-outs unless you spurge for the $700 Tokicos.
regal is offline   Reply With Quote
Old 10-02-2009, 07:54 AM   #22
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
yeah, thats why there are These
Old 10-02-2009, 01:02 PM   #23
kngrsll
Apexing Egg!!
kngrsll's Avatar
or, you can run higher rate dampers. i havent tried it myself yet, but i am going to see if Fit dampers will fit on the yaris. We have two sets of stock suspension sitting at the shop, my old stock suspension and my buddies Fit suspension. they are remarkable very similar. the rear shocks and springs look identical, which is what started us down this path in the 1st place. The rear springs work perfect. The dampers look like they may be the same story. I will get around to fitting them when i am done with my medical rotation here in michigan so we can konw for sure. then, if you run higher rate springs, you can run the higher rate dampers to go alone with it. if not, the rear shock is about as basic a design as you can get so it will be very easy to find a substitute design. if this doesnt work, you can use the xD rear shocks, which will allow for higher rates. 350 lb springs are really not that heavy anyways, especially with all the shock travel we have in the back. when i spoke to the technical team at tokico, they said that the HTS shocks will easily handle spring rates over 500 lbs. at 350, we are not even pushing their limit. if you dont have a ton of cash, you could only upgrade the rears and use blues in the front. or you can use blues all around and use xD rear shocks. someone should check and see that they have different part #'s first rather than assuming they are different. also, using the old shock dyno i posted, you may be able to assertain what the max rear spring rate is by comparing the dampening of the blue and HTS since the dyno plots those two variables along with the stock shock.
anyways, lots of options if your mind is open. beware, more innovation and creative ideas are coming ;)
Old 10-20-2009, 06:42 PM   #24
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Any updates?
Pictures of this set-up would would be even better!
I would like to see the stock Honda Fit spring set-up.
I have a '09 Honda Fit Sport that I want to drop and it would be cool to only have to buy one set of springs!
JTDBT903 is offline   Reply With Quote
Old 10-23-2009, 12:53 PM   #25
randode
randode's Avatar
Drives: Toyotas, Scions, and Cubes
put airbags on the rear in place of springs, and carry as much weight as you want.
randode is offline   Reply With Quote
Old 10-23-2009, 01:06 PM   #26
lilredrocket
Slowy getting there
Drives: 08 Liftback
Ummm. Springs are better for racing I believe.... If I'm worng someone please correct me
Old 10-23-2009, 01:17 PM   #27
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
show before go. always.
welcome to the world of typical scion owners. didn't you specialize in LED's and cathode tubes for the xB's ?
Originally Posted by xnamerxx
you nailed it sir.
Old 10-23-2009, 04:26 PM   #28
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
see link in his signature.....
Old 10-23-2009, 05:29 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
ah my boyfriend is here !!!!
thanks capt obvious, i would have never thought to click links in his signature..
you nailed it sir.
Old 10-23-2009, 06:02 PM   #30
if you mean the new adjustable HTS "reds", they are less than $600 in my store. Shipped.
toyota yaris vs 09 honda fit ..philippines i think marcus General Yaris / Vitz Discussion 15 12-02-2010 07:01 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 05:24 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
