The danger with the roof pilar is making a left hand turn. It can very easily block off a pedestrian crossing the street. You really need to makean effort to look a few times.
![]() ![]() Drives: Black '07 HB A Join Date: Jul 2007
That is so true. There is 1 company adressing this problem, I think its Volvo. They put in 3 small solid metal supports(in a triangular shape) with 45 degree bracing between them, and wrapped it in a clear plastic. You can see right through it.
![]() ![]() Drives: 2010 Toyota Yaris 2 DR LB Join Date: Oct 2009
#4 | |
![]() You're driving a vehicle a ton. You should probably "make an effort to look a few times" regardless of the pillar situation. I agree with PK. Move your head, sit up straight(you'll be able to reach the steering wheel that way too.....) and there isn't a problem. |
I've noticed with cars with side curtain airbags that the front a pillars seem to be larger. I'm guessing this is to hide all the hardware that comes with the side curtains. just move your head around to look I've found it easy to adapt to.
Half a Bubble Off Plumb
Yep, the airbags make the pillars bigger out of necessity. All cars have blind spots. You need to learn where they are and be cautious about them. As mentioned, head movement lets you look around them. If you're not careful, people and cars can be hidden in them.
#7 | |
Toyota is making millions of vehicles weighing over a ton. Itd be a lot better if they made them so you can see out at all times. Probably more effective than pillar air bags. (being able to easily and intuitively see peds) |
| Drivers Side Seat Belt Won't Retract | redyaris | DIY / Maintenance / Service | 8 | 08-07-2014 10:37 AM |
| Thailand OEM/Aftermarket Accessories and Bodykits GB Round 2! | eTiMaGo | Items for Sale by private party | 118 | 09-10-2007 02:10 PM |
| Side skirt and front spoiler. | Boo | Cosmetic Modifications (Exterior/Interior) | 18 | 09-19-2006 04:18 PM |
