Old 10-25-2009, 09:55 PM   #1
posaunemeister
Drives: 2008 Yaris S LB - MM
For my stock airbox, I did a few steps:
1. Used a dremel to cut out the mesh filter padding that is located in the top part of the airbox, and then blew out all of the residual particles with pressurized air.
2. Replaced the stock filter with a K&N replacement.
3. Opened up the driver-side fog light cover and covered it with 3 layers of screen mesh (to keep dust and debris from entering the engine bay).
4. Hacked off half of the bottom part of the snorkel, rotated it 180 degrees so that it points downward, and then attached a series of PVC piping that leads to the back of the fog light cover, so that my forward motion will aid the intake process. I superglued the snorkel into place, the PVC piping is secured by rubber couplers and the wide-mouth PVC coupler that leads into the fog light is secured by several plastic fasteners.
I've noticed a very big improvement in terms of throttle response and acceleration, especially as the weather chills up more and more. Obviously, I get the best results at night. The only downside is that I get a little worried anytime I have to drive over 40mph in the rain...
posaunemeister is offline   Reply With Quote
Old 10-25-2009, 10:06 PM   #2
As you should be. Last February a member who hydro-locked and killed his engine posted this response when asked how it happened.
Originally Posted by Adriaan View Post
i had switch the stock intake nozzle from the curve to a 45 degree elbow pointing down with a 4inch length hose. I helped alot on my long distance drive to and from montreal great gas mileage. Didn't think it would be the killer for my car. Never again staying with the stock tubing.
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
TRD Cold Air Intake IN STOCK!! Sparks Toyota-TRD Sparks Toyota 2 05-11-2009 04:03 PM
Stock Intake Manifold gwasabi Willing to Buy by private party 0 05-04-2009 05:32 PM
WTB: Stock intake rubber tubing spkrman Items for Sale by private party 8 02-04-2007 11:09 PM
