Old 10-26-2009, 10:05 AM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Hi H3LlIoN,
No one has posted that because the cheapest gas is almost never the best bang for your buck. To make a long and scientific story short, the gasoline brands are usually separated by no more than the mandated additives they use. The top tier oil companies spent billions of dollars in research and development to figure out how to make those additives combustible, meaning that they do not rob the underlying gasoline of power per volume, and also burn cleaner in your engine. The cheaper providers do no such thing, so not only does their gasoline not burn as cleanly (which can leave some nasty gunk behind) but it has less caloric content per gallon, meaning you don't go as far on a tank.
All of this means that while you may find a cheaper price at a pump you will most likely end up at another pump sooner, so you actually spend more money on cheaper fuel rather than save anything.
As to why the price of gasoline is going up right now, it is mostly due to the increasing demand in the U.S. (likely from children being back in school, and their parents insisting on shuttling them in their gargantuan SUVs).
- Brian
Share the Road
Old 10-26-2009, 10:37 AM   #2
Hi H3LlIoN,
Again, Brian assumes everyone outside his world drives a gargantuan SUV. Here is a list of cars that parents from my sons pre-school drives. I see them on a daily basis:
Toyota Yaris -- Me
Toyota Camry Hybrid -- Parent
Saturn Vue Hybrid -- Teacher
Toyota Yaris Sedan -- Parent
Honda Civic Hybrid -- Parent
Honda Accord -- Parent
Toyota Prius -- Parent
Toyota Prius -- Teacher
Just a short list of the ones I see on a daily basis. If your looking for more fun facts compared to the area I live in, here the zipcodes for the school and surrounding areas : 22066, 22102, 22101. I'm sure you'll find that they can afford the big SUV's and the gas in takes to run them.
Currently the gas around my house is $2.39 at the Shell. Costco is at $2.36 and so is Sheetz.
Old 10-26-2009, 11:28 AM   #3
H3LlIoN
Drives: '09 Yarrrr hatch
I'd be bitter too if I was from Nevada, given the reports from friends I have out that way, as well as the news. We Virginians on the other hand just got named in the top 5 states to start a biz, not that you'd want to right now.
Anyway, given that long thing about caloric content and additives and what not, what is generally accepted as the "healthiest" gas?
H3LlIoN is offline   Reply With Quote
Old 10-26-2009, 12:22 PM   #4
BailOut
BailOut's Avatar
I hate to sound like I'm endorsing any particular oil company, but here it goes. Anything in this list should do: http://www.toptiergas.com/retailers.html
... but we hypermilers have run millions of miles of road tests and have found that Shell and Chevron consistently offer the best mileage. This has been tested to the point that whenever someone holds a fuel economy challenge, most of the contestants show up with Shell in their tank.
- Brian
Share the Road
Old 10-28-2009, 01:55 AM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Okay, so I've never really believed in this before and have always used cheaper brands of gas, as long as the station looked somewhat decent. I can count on my fingers how many times I refueled from anything other than ARCO and COSTCO over the past 3 years.
I've had my Yaris for 2.5 years now and I'm approaching 20k miles on the odometer. Is there a way to check if the cheap gas did any "damage" and how can I clean it up? Will using "good gas" clean the engine over time or do I need to actually do something about it? Are the "injection cleaner" products at the gas stations any good?
I am starting to get swayed by all the arguments here and ever since I started all these projects on my Yaris, adding all the mods, I've become more aware. Just as an example, 3 weeks ago I got the first full synthetic oil exchange... since I'm revving it close to 4,500 rpm a couple of times a day
Any advice will be appreciated
fmicle is offline   Reply With Quote
Old 10-26-2009, 11:38 AM   #6
ddongbap
Toyota Yaris -- Me
Old 10-26-2009, 12:56 PM   #7
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Hi H3LlIoN,
+1
People will drive out of their way to save $0.03/gal and buy shitty fuel. Doh!
And FTR, Hybrids are the biggest scam going.
RUFFSTUFF is offline   Reply With Quote
Old 10-26-2009, 12:56 PM   #8
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
+1 to that :)
Old 10-26-2009, 07:52 PM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I just don't see how they save enough to be worth the added cost. They save some gas but a hybrid SUV is kinda like ordering a Double Quarter Pounder with Cheese combo and a Diet Coke-sure the Diet Coke helps some but you could of just ordered a salad...
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 11-24-2009, 02:24 PM   #10
SilverGlow
Drives: 2007 Yaris Hatchback
Hi H3LlIoN,
Lots of untruths here.
First off, in nearly all instances, gasoline is now a commodity, and the only difference between brand X and brand Y is additive package. The base gasoline on most instances is the same. In other words, most of the Chevron, Shell, Arco, and mom-pop gasoline comes from the exact same refineries, same pipes, same everything...again the only difference is the additive packages....some use Techron, others use chemical XYZ, but all brands have to add additives that meet the mininal requirements of the state and federal government.
Now having said all that, I buy mostly Chevron, for their flavor of additive, knowing full well the underlying base gas is the exact same as the Arcon across the street, or the Mom & Pop down the way.
When you buy gas, go for the best additive packages...really that is the only thing that differs between one brand and another.
Also, no gas company has spent "billions" on gasoline R&D....never happened...gas is not rocket science and has been around for over 100 years.
SilverGlow is offline   Reply With Quote
Old 11-24-2009, 02:47 PM   #11
BailOut
BailOut's Avatar
SilverGlow,
That's quite a confusing post. Though you seem to disagree with me your entire first, second and third paragraphs confirm exactly what I said, and your statement about there not being billions spent on additive R&D is laughable.
I'm not sure where you get your information from, but as a hobbyist investor I read many company balance sheets each year. I can tell you that from the 1970's through today that each of the top tier companies has indeed spent billions of dollars in additive R&D as they show this as a justified expenditure against their market capitalization, as well as providing their prospectus with a future-positive bullet or two. Every time a fuel regulation changes there is another spate of spending.
I can also tell you that the non-top tier fuel providers simply buy their additives from a tertiary company that offers their stuff dirt cheap, and that stuff is dirt cheap because it only does just enough to meet the mandates in the cheapest way possible.
Please research this topic more before posting again.
- Brian
Share the Road
Odd Metallic Sound From The Engine Bay Kaotic Lazagna DIY / Maintenance / Service 5 08-29-2009 03:03 AM
Odd Noise when breaking brotan1x DIY / Maintenance / Service 18 08-27-2009 10:10 AM
Odd looking vitz YAR1S Photo-Video-Media Gallery 2 04-23-2009 09:53 AM
I LOVE my Yaris but......... Driver General Yaris / Vitz Discussion 37 12-04-2006 11:48 PM
Hmmm... Seems odd that this is missing. IsLNdbOi New YARIS Purchase Forum 18 09-02-2006 08:37 AM
