Old 10-27-2009, 10:14 PM   #1
Yarold n Kumar
Yarold n Kumar's Avatar
Drives: 2009 3dr lb
does the egg shape cause turbulence in the back when we go fast?
Yarold n Kumar is offline   Reply With Quote
Old 10-27-2009, 10:56 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
The blunt rear end causes a low pressure air bubble behind it which may or may not increase drag. I believe the bubble helps out, because when mythbusters tested which is better, whether to leave the tail gate up or down on a truck for aerodynamics, they found that up was better because the low pressure air bubble that formed inside the bed helped direct air around the truck. Also, the drag on the sedan is the same as the LB so my guess is the air bubble is directing the air around the car.
Old 10-28-2009, 12:44 PM   #3
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Did you guys see the one where they covered a car in clay and cut dimples in it, to replicate the golf ball surface? And the mpg improved like crazy?
I'm thinking about getting the mallet out and start working on the body...
fmicle is offline   Reply With Quote
My new wallpaper aka Yaris Photoshop thread eTiMaGo Photo-Video-Media Gallery 109 04-02-2010 02:03 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
