Old 10-28-2009, 09:31 PM   #1
SEALL
Drives: 08’Yaris
Thanks for all,i checked the PIN 40 on the ECM yesterday,but it was no volts on it,so i can confirm that the CC pin on the ECM wasn't actually used for Chinese market.
thank you for all the help.
SEALL is offline   Reply With Quote
Old 10-28-2009, 10:59 PM   #2
Maybe you should buy a USDM ECM off ebay. Then, you'll have the only Yaris in China with cruise control.
Old 11-03-2009, 07:45 AM   #3
SEALL
Drives: 08’Yaris
hahahaha~~~good idea!but how much the USDM ECM? and I need to change the ECU or ECM's Program? or install it directly into the in-situ and do not change anything?
Old 11-03-2009, 07:51 AM   #4
I'm not sure about the compatibility, but USDM ECMs can often be purchased for under $100 off ebay. The engine type, transmission type, ABS yes/no, and VSC yes/no are important to match when swapping ECMs. Our USDM ECMs are for 1NZFE and 2NZFE engines. I haven't noticed which engine you get over there.
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
