Old 10-31-2009, 04:04 AM   #1
sabya78
Drives: Yaris
I installed the CC, when I switch it on the speedometer jumps once , pressing the set buttom dosen't set the speed . While installing , by mistake I connected the 12 V supply instead of the ground which stalled the engine immediately . Can anyone help me if I have screwed up the CC function of my ECU. The car is running fine otherwise.
sabya78 is offline   Reply With Quote
Old 10-31-2009, 07:18 AM   #2
So far it looks like only US and Canada Yaris have the cruise functionality built into the ECM. In the UAE do you get European Yaris? If so, cruise is definitely not built in.
Old 11-08-2009, 05:28 AM   #3
sabya78
Drives: Yaris
The part number on my ECM is 89661-52C00
Old 11-08-2009, 07:55 AM   #4
I would say that there is a good chance that that ECM doesn't have cruise control, as that part number is not a USDM/CAN one and so far it appears that just ECMs for those markets have the functionality. One test that you can try is to measure the voltage on pin 40 of the ECM connector A21, with the connector in and the ignition in the ON position. If you measure +12VDC to ground on that pin, then there is a good chance that your ECM supports cruise. If you measure 0 VDC to ground, then it definitely does not.
Old 01-14-2010, 09:00 PM   #5
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
help?
Hi guys im new here , joined because im getting my yaris tomorrow and was intrigued by this mod.
Can someone show me with microsoft paint maybe, how i can wire up this switch?
http://www.alliedelec.com/search/pro...px?SKU=9485541
~mkie~
t2mike2 is offline   Reply With Quote
Old 01-14-2010, 09:31 PM   #6
~mkie~
Old 01-15-2010, 01:16 PM   #7
t2mike2
Thanks alot dude that is VERY very helpfull, very excited im going to pick up my yaris now. I'll post pics when this mod is done.
Thanks again.
~Mike~
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
