View Poll Results: Whats the best header? Pure performance....
DC 24 72.73%
AMK 1 3.03%
MEGAN 7 21.21%
Thunder 1 3.03%
Voters: 33. You may not vote on this poll
Old 11-03-2009, 09:37 AM   #1
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
well everything I have read says that a good header does make a difference... do you have proof otherwise...remember your on a modders forum...
chongopants is offline   Reply With Quote
Old 11-03-2009, 10:41 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
show me dyno sheets of before/after the header
Old 11-03-2009, 11:04 AM   #3
hatchbackkid82
Drives: .
I say get it don't let the naysayer's on here get to you. The header does make a difference, of course keep in mind that it won't be 15hp-20hp, more like 1hp-4hp, it all adds up though if you're going to be doing other mods to the car.
Old 11-03-2009, 12:50 PM   #4
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
The header alone won't make a big difference, since the stock intake and exhaust are so restrictive, but the general wisdom is that if you get all these mods, together they will give you a better improvement than each one of them counted separately.
As for the bracket misalignment, it happened to me. The header is attached to the engine block with at least 4 bolts (if not 6, can't remember exactly) and 2 spring bolts to the exhaust pipe, so it's definitely not going anywhere. I don't think it really needs the extra support the bracket will give it, that's why I didn't worry much about it.
There is a removable steel bracket (painted black in my car) that's attached to the engine and then there is a smaller bracket welded onto the header end. If this weld isn't perfect, as in if it's off my 1 mm, the holes won't align perfectly and the stock bolt won't fit, since it has to be threaded into the DC bracket. That's what happened to me, so I took a smaller bolt and nut and just fastened it like that. Ghetto-licious
fmicle is offline   Reply With Quote
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
can someone meausre their stock or a/m header? thebarber Performance Modifications 8 12-15-2008 06:13 PM
