Old 11-03-2009, 05:34 PM   #13
2009Toyotoad
Drives: 2009 Yaris 3dr
We tow our 09' 3Dr MT behind the moterhome. However, because the aux braking system needed 12volt power we leave the battery connected. I was going to pick up a haedware store key to determine if the engine imobilzer effects the battery too, but haven't had the time yet. because It really light weight it tows well.
At 2,200 lbs state regs required the AUX braking system in California. Some folks with Diesel motorhomes run the Aux brakes off the diesel's compressor. No idea how that works in a break away situation.
Truthfully, don't want to find out how our system performs in break away either. but because its all "onboard" the car, I don't worry that a high pressure hose will break away before the break away ping get pulled. Setup for this kind of stuff is pricey, $5K. But I noticed the front mounting plate for the tow bar hook ups really stiffens up the front end under non towing cornering turning situations. Nice handling minimal fender flex.
2009Toyotoad is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 07:07 PM
