Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 11-05-2009, 06:22 PM   #1
mrloseth
mrloseth's Avatar
Drives: 1,5 turbo yaris 2005mod
Originally Posted by CASTREX View Post
These numbers don't tell much unless you can add the boost figures also. It does a bit lean at 2800 as you said if you are indeed boosting at that RPMS.
It does also look quite rich at the top end... if you could lean that out you will gain some power up top.
How many psi are you seeing at 2500/2800 rpm?
Overall it doesn't look bad. You have enough fuel obviously. Some fine tuning would help. Why don't you try getting a SAFC or a greddy emange? You should be fine if you build a full exhaust.
i got 0,5 bar boost at 1700 rpm and i have the same boost att 6200 rpm.. the car is now totaly stock.. so you think that it wouldnt be a problem to bouild exhaust now?:)
mrloseth is offline   Reply With Quote
Old 11-06-2009, 10:59 AM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
if you are running stock boost on the original ECU you are OK to build an exhaust.
OK so you are hitting full boost at 1,700rpm so it seems like you are running a bit lean from 1,700rpm to above 3,200rpm I would still think about some sort of management like a emanage, SAFC, AEM FIC so you can load a smother curve. But overll you seem to be fine. TRD knows what they are doing... and as long as you don't raise the boost, an aftermarket exhaust should not be a problem.
Old 11-10-2009, 08:13 AM   #3
mrloseth
mrloseth's Avatar
http://www.greddy.com/products/displ...SubCategory=47
it seems like they have kit also for my car?
is it difficult to program this?
Old 11-10-2009, 10:59 AM   #4
CASTREX
CASTREX's Avatar
Yep they do. Is not difficult if you know what you are doing... If you understand the basics of engine tuning and are willing to take some risks you can do it your self. My advise, look for a local Emanage tuner. This is a very popular device, finding a tuner for it shouldn't be that difficult.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
