#1 | |
Economist
Drives: 2007 Yaris Lifback Join Date: Oct 2009
The P/S light went on again tonight on the way home as soon as I started the car. I stopped and checked the codes immediately -- 91 and 92 again. This got me to thinking... there are three ECU codes for connection with the ECM with DTCs unlike the others: U0073, U0105, and U0121. It also states "When two or more DTCs starting with [U] are output simultaneously, inspect the connectors and wire harness of each ECU." I accidentally did some slight damage to the plastic white connector on A21 when I was installing cruise control recently, but I didn't think much of it. I wonder if this might be related. I'm going to double-check it. UPDATE: I pulled A21, inspected it, pushed locking mechanism back in fully, and reattached. So far no trouble. I am going to have the dealer read the code with the intelligent tester when I take it in for the 25,000 mile service this coming week. I'll let you all know what they say -- hopefully it may help someone else with the same problem searching the boards down the line. Thanks again for all the help so far! Last edited by sıɹɐʎ; 11-06-2009 at 11:25 AM. |
#2 | |
Economist
Economist
I went to the dealer and their response was "the intelligent tester won't help. If the light isn't on now then everything is fine." I didn't have the service manual with me, but unless I'm pretty sure that it describes how to use the intelligent tester to read the trouble codes from the Power steering ECU. Am I wrong?
#4 | |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| power steering | cali yaris | Performance Modifications | 27 | 04-24-2010 08:43 PM |
| --- Does power steering turn off at high speeds? --- | basslover911 | Tracking, Racing, Auto-X Forum | 7 | 10-12-2009 12:21 PM |
| FREE Sciontech power steering resivoire cap | YarisSedan | Items for Sale by private party | 3 | 04-27-2009 09:40 AM |
