View Poll Results: Is this for real?
I think there's something to this... Toyota should investigate! 15 35.71%
No way! This is just another lame attempt to discredit Toyota. 27 64.29%
Voters: 42. You may not vote on this poll
Old 11-07-2009, 11:02 PM   #11
H3LlIoN
Drives: '09 Yarrrr hatch
The DBW system has two separate accelerator position sensors for redundancy. If either sensor fails (or the wire to it becomes a short or open) it uses the other (and throws a DTC) if both fail it brings the engine down to idle.
With millions of these cars on the road running for zillions of miles and 2000 "possible" cases, it is a fairly low risk of occurrence issue. Reading the service manual about how the DBW works and the built in safety checks, in theory it should be as or more safe than a mechanical throttle linkage.
Take the number of vehicles in the field, A, multiply by the probable rate of failure, B, multiply by the average out-of-court settlement, C. A times B times C equals X. If X is less than the cost of a recall, we don't do one.
Seriously though, I'm totally using this as an excuse on my next speeding ticket.
H3LlIoN is offline   Reply With Quote
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
