Triple C Design pod finished and installed
here we go, the moment we all been waiting for.
Triple C design: Model "T1G2" ![]() ![]() ![]() ![]() ![]() Sample getting ship to Garm on monday and we are just waiting for approval.
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
awesome!
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
here again..
ok, for the install we'll be making a DYI and we'll also include it with the pod, video will be up soon..
Don't be threating me with a good time!!!
pink wheels are cool
so how does it attach? by those 2 big bolts on each side?
would of been cool if you lowered it so it fit around the steer wheel plastic so the door could open |
Kickin' Yaris
Drives: 07 Yaris liftback Join Date: Oct 2008
meh- looks really bulky, and I wouldn't want to lose the glove box
#6 | |
you can still use the box, the door does not open all the way but can still storage stuff there.
hot glue would be the best i guess
the bolts make it look cheap |
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Can you fire up the car and drive it around so we can see this in action?
★weeaboo★
Ugh, it looks so good. (I'm annoyed because the TRD gauges by Defi are so expensive. ;_; )
FYI I believe even the factory pod installs with bolts. Four of them IIRC. |
here again..
the pod will be shipped without any holes, that way for those who want to "hot glue it" they can, as far as the bolts, 1- the original (see: http://www.yarisworld.com/forums/sho...t=23584&page=2) it uses 4 instead of 2, 2- they are not that big once it's all together and 3- this is our first model as we go I'm sure better ideas on how to install it will come out, also as far as still be able to use the compartment, you can, you can install the pod as low as touching the steering column, the lower it goes the more the door will open, it's that simple....
next question...
#13 | |
here again..
1-depending on the user gauges may be different 2-installs are also different by the user, one may installed different than others 3-the pod function is only to give the user the placement for whatever gauges they need/want, VAC, TEMP, PRESSURE etc... for these many variables the gauges that are there are just for you to have a good idea of the final look, also AND THIS IS VERY IMPORTANT: different gauges/tach brand have different depth so, the pod was build to hold certain max depth anymore than that and you'll have to "cut" the door to fit them, in the install pics/videos we'll go over everything... next question...
#14 | |
here again..
'nuf said!' ![]()
#15 | |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
losing the glove box would be something I wouldnt do considering I use the toll 4 times a day
Sold the yaris... rocking an 89 vw cabriolet now :) |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
+2. This showed much promise, but I'm not too crazy about that size blocking the door and having to cut into it for the center gauge. Originally I was thinking you were building an exact replica of the one in the pics I posted in the initial thread. Sorry guys, have to pass on this (at least until it's redone)
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
theres something about it that doesnt look as slick as the TRD one
maybe because the TRD one is smaller and thinner? hmmmmm |
Riceman43
I have to agree...It just seems out of place to me...Wish you could make it smaller somehow...
