![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Can you fire up the car and drive it around so we can see this in action?
★weeaboo★
Ugh, it looks so good. (I'm annoyed because the TRD gauges by Defi are so expensive. ;_; )
FYI I believe even the factory pod installs with bolts. Four of them IIRC. |
#3 | |
here again..
'nuf said!' ![]()
Don't be threating me with a good time!!!
#4 | |
here again..
1-depending on the user gauges may be different 2-installs are also different by the user, one may installed different than others 3-the pod function is only to give the user the placement for whatever gauges they need/want, VAC, TEMP, PRESSURE etc... for these many variables the gauges that are there are just for you to have a good idea of the final look, also AND THIS IS VERY IMPORTANT: different gauges/tach brand have different depth so, the pod was build to hold certain max depth anymore than that and you'll have to "cut" the door to fit them, in the install pics/videos we'll go over everything... next question...
