Old 11-11-2009, 12:40 PM   #1
bronsin
bronsin's Avatar
Wow my black 2009 had scratches there when I bought it I didnt notice beforehand. Im thinking youll get less than 250 miles on the second half of the tank. When mine hits four bars it takes 6 gallons to fill it.
Old 11-11-2009, 01:27 PM   #2
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
half a tank is exactly when 5 bars goes to 4 bars. should be about 200 miles
driven and 200 miles left. give or take a buncha variables.....
the first bar is dang slow to move, but my scangauge and calculations reveal the
gas gauge is actually accurate once it gets off the first bar, and half a tank is -really- half a tank (go figure)
127.0.0.1 is offline   Reply With Quote
Old 11-11-2009, 02:13 PM   #3
db662
Drives: 2010 yaris
I'm very impressed with the gas mileage so far. The dealer told me that the "i" in the vvt-i means "intelligent" which she equated to meaning that the engine will learn the way I drive, so I guess the gas mileage will change once it gets used to me?
So the rear sway bar is a good mod to get? Will that affect the ride of the car? Because as it is now it rides great, so far it seems to handle very well with a "nimble" kind of a feel.
db662 is offline   Reply With Quote
Old 11-11-2009, 04:50 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
It's probably the single most "must-have" mod recommended by those who've put it on. It will stiffen up the rear and help you corner even better making it even more nimble.
Old 11-11-2009, 05:12 PM   #5
goku87
goku87's Avatar
Drives: Black HB
Your new toy
Congrats. Mine just got totaled on the 7th.
That noise you hear is actually because of the type of gear used for reverse. Most of the tranny has helical gears, which helps disperse the torque evenly across a number of teeth. With reverse, they just use a spur gear, which puts all the pressure on one tooth at a time. And since mechanical things need space to move, the space between the teeth causes the teeth to *clink* together (unlike helical gears). This sound in rapid succession causes the toy car sound you hear.
http://en.wikipedia.org/wiki/Gear
goku87 is offline   Reply With Quote
Old 11-12-2009, 02:26 AM   #6
RedRide
RedRide's Avatar
The ECU will moitor you driving habits and tune it acordingly. either for more economy or more performamce.
For example: It you often go for WOT, it will assume you want performance over economy. Personally, I go for performance and the gas mileage is still great.
If you are happy with the ride, fine.
However stock, the Yaris has a great deal of body roll and under stear in turns.
A a rear sway bar eliminates this and makes the Yaris more fun and safer to drive
Just Picked Up An 09 Yaris So Hello!!!! arcticvitz California 14 03-22-2009 01:48 AM
Yaris review from the NY Daily news bobselectric General Yaris / Vitz Discussion 3 03-07-2009 02:28 PM
Picked up new (to me) Yaris yesterday ! yaris prime General Yaris / Vitz Discussion 22 02-27-2009 10:29 AM
