![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Add this to the list:
If you never did this I would change the trans/axle fluid. Also see if toyota has a water pump lube and conditioner to get that LL coolant to 100K w/o the pump failing. my 05 rav pump seal gave out at 60K - it shouldnt have. |
#2 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Better to go with the owners manual and you'll see that the trans need not get flushed/fluid replaced until 100,000 miles. And no need to worry about the water pump. Just go with the manual and you'll be fine. |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 09:00 PM |
| Why does 15000 service cost so much more than 5000 and 10000 mile service? | monyaris | DIY / Maintenance / Service | 7 | 06-25-2009 07:12 PM |
| 10,000 mile service | lindstothek | DIY / Maintenance / Service | 7 | 01-21-2009 01:42 PM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 12:40 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 03:14 PM |
