Old 11-13-2009, 07:16 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm seeing the same. Like Goku mentioned, if one of us put together a dual alternator setup, with one isolated for the use of the sound system...
― Thomas Paine
Old 11-13-2009, 11:45 AM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if somebody had the means to fabricate custom brackets that would probably be the best & cheapest way as you can often go to junkyards and find alts for under $20... I remember a few years back in Spokane,WA there was a junkyard that would sell you alts for $8... tho you had to remove it yourself.
The yaris/echo has been out long enough to have a few cars in the junkyard by now. Tho... if I was going to do custom bracket... I'd be tempted to just pull one from a truck that had like a 100-140amp alt.
one drawback to dual alts would be more load on the engine than a single alt, thus lower mpg's... prolly less than 1mpg difference tho.
EDIT:
Architect
I'm starting to wonder if there is something weird with your car... you dropped cable a while back and then said your voltage was funny after that.... Did you have your battery tested.... maybe you have a bad cell in your battery that is causing a wierd issue.... constantly trying to charge thus sucking amperage, thus lowering voltage... i dunno... be worth checking out tho.
Old 11-13-2009, 04:29 PM   #3
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
EDIT: r
Architect
Yea when i did that I essentially grounded the stock alternator which mustve messed up some of the internals causing it to charge poorly.
My yellow top sits at 12.75 cold and the alt charges normally.
Ill just take my battery to autozone for a battery test but a hot test would be misleading so idk
PG TLD22 8V Line Driver
Old 11-13-2009, 05:09 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Hook it up with daul "Walmart specials" now... get two of the walmart everstart 1000CA bats.. they are like $70-80 a pop... run them in parallel... will have way more performance than any single car audio battery would have, and cost the same as a yellow top.
Had a buddy run three or four of those in his civic hatchback... think he fit them all in the spare tire well too. Maybe he had one up front.... long time ago... hard to remember for sure. He was running round 4kw's and a 0.7ohm load on 2ohm amps ... fun times.
Old 11-14-2009, 01:40 AM   #5
goku87
goku87's Avatar
Drives: Black HB
Three words:
Sulfuric acid fumes.
Not so fun times.
goku87 is offline   Reply With Quote
Old 11-14-2009, 09:08 AM   #6
The Architect
Give Me Resonance
Originally Posted by goku87 View Post
Three words:
Not so fun times.
idk whats going on with both yours and his statements haha, maybe its bc i read them when i was half unconscious
Old 11-16-2009, 11:34 AM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Three words:
Not so fun times.
Three words
Vented battery box
if it's really a problem you just have to seal the batteries in a box, and then make a vent that goes outside so the fumes don't get in the cabin of the car. I question how much of an issue that really is anyway.
If the box is too much work... could try and find the cheapest sealed/non-venting batteries you can get.... do the Exide orbitals release gas? they aren't that expensive are they.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
The Big One upgrade fuji DIY / Maintenance / Service 2 02-15-2009 02:37 AM
N/A stage 1 upgrade? forpinks Performance Modifications 12 03-18-2007 08:42 PM
