#1 | |
AKA Samurai Racer
where is that connector buddy ? i wanna hook it up to my apexi rsm speed wire |
Pop the trim from around the speedometer and you'll see two connectors going to the cluster assembly. If your car is left hand drive the connector you want will be on right and if it's right hand drive it will be on the left.
AKA Samurai Racer
aaah ok ! thx bro !! no other locations for that wire ? like on the ODB2 port? how does the scangauge get speedo signal? cant i somehow hook into that?
The ScanGauge gets it via CAN Bus data at the OBD port. If your car has TPMS the speed signal is available there as well. honestly, popping the trim from around the cluster takes no tools and just a couple of seconds.
#5 | |
AKA Samurai Racer
im a little scared to mess up the plastics as i have a heavy had. how does that plastics come off anyway? |
#6 | |
Pull the cluster trim gently at the top, where the seam is to loosen it. Pull the cluster trim along the bottom straight back towards you to free the tabs that go into the top of the radio trim. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
