Old 11-17-2009, 02:34 PM   #1
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Originally Posted by SilverGlow View Post
For what years Yaris?
Mine's a 2007, in Canada. The specs stay the same up to 2009.
It would be interesting if the US and Canada have different specs, yet relatively the save climate (save for far South, or far North).
A proper flush, with a car lift, is easy to do. They have to hook up a "dummy" electrical current to engage the transmission pump, to flush out all the fluid (along with the pumping of the flush machine itself - this is per the shop manual). You can drain and fill it yourself, but you're only getting a little over half the fluid out at a time. Even if you do your own disposal in someone's dump fluid tanks, it'll take roughly twenty one quarts to flush the majority of it out. For that price, you may as well just get it flushed by the dealer. I'm sorta on the fence in regards to pan drops. Yes, there is a mesh filter in there that theoretically needs replacing, but the likely stripped hex bolts that result from trying to drop the pan, as well as possibly warping the pan, or worse, the interference surface of the pan, makes me think it's just not worth the risk. As always, that's something up to you to decide.
The only extra advice I can add is that once the fluid is flushed by the dealer, make sure he checks the level while the fluid is warm: Once again, all the info is available in the shop manual, which is available for download somewhere on YW.
firemachine69 is offline   Reply With Quote
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 09:00 PM
Why does 15000 service cost so much more than 5000 and 10000 mile service? monyaris DIY / Maintenance / Service 7 06-25-2009 07:12 PM
10,000 mile service lindstothek DIY / Maintenance / Service 7 01-21-2009 01:42 PM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
