Old 11-19-2009, 12:49 AM   #1
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
All maintenance requirements based on mileage intervals
Here's an invaluable link for each 5K service requirement up to 120K:
http://www.toyotaownersonline.com/pa...rvice/diy.html
Mods: please sticky this
Old 11-19-2009, 12:50 AM   #2
tomato
tomato's Avatar
Totally. Thank you!
Old 11-19-2009, 12:53 AM   #3
SilverBack
Joey
SilverBack's Avatar
You're welcome
Old 01-09-2010, 07:04 PM   #4
bankrobber
Drives: 2007 Yaris Hatchback
I checked every service interval and none said to change manual transmission fluid or coolant.How caan that be?
bankrobber is offline   Reply With Quote
Old 03-06-2010, 10:33 PM   #5
Kal-El
Kal-El's Avatar
I checked every interval and didn't see any tranny fluid change (not even automatic). Surprised.
It does mention coolant at 100K and then every 50K thereafter.
Spark plugs at 120K.
Other than that, nothing else is listed to be replaced or changed other than oil, tire rotations, and air filters except for inspecting things.
Old 01-24-2010, 04:48 PM   #6
cowboy
Drives: yaris CE 2007
howdy all
anyone in Canada have the Data Tester available to be used for Diagnostics ..... if so pls write to Cowboy thanks
cowboy is offline   Reply With Quote
Old 03-07-2010, 12:48 AM   #7
Ryu
http://www.toyota.ca/cgi-bin/WebObje...110000e%2ehtml
There you can check all your maintenance interval.
Auto transmission is to be changed 96000km >>192,000km >> 288,000km >>384,000km
Old 05-14-2010, 04:45 PM   #8
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
here's another that covers all toyota models
http://smg.toyotapartsandservice.com/
OTA'sTOY is offline   Reply With Quote
Old 06-01-2010, 08:04 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
Old 08-31-2010, 01:21 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wow spark plug change at almost 200k
Old 10-20-2010, 10:54 AM   #11
mojokin
Drives: 2010 Toyota Yaris
Thank you guys for the links.
Here in Manila we do a 5000 km interval. The service advisers are insistent on this schedule. Since you use miles, you get 3000kms more between service schedules. You get to save more.
mojokin is offline   Reply With Quote
Old 01-04-2011, 03:53 PM   #12
Vinceb
Drives: 2008 5 Speed Sedan
do you need to complete everything they say?
I probably drive my Yaris alot more than most people, and i'm approaching the 128,000km service (approx 80,000 miles) it's a 2008 so really I shouldn't be at this servicing for another 1.5 - 2 years according to the dealer.
it's getting quite expensive, this service i've got:
Maintenance Service (104.99) - Inc oil filter and change
Cabin air filter - don't care, i clean it myself
Manual transmission fluid (37.95) - Drain and fill - not a flush
Super long life coolant (65.95) - Drain and fill - not a flush
208 + tax and thats assuming I don't need brake pads or anything else.
I've followed every service so far in the manual, always on time, never missed anything - no warranties left on the car except maybe major emissions. do I really need to keep doing all this or can I just go with oil changes?
No problems, love the car works great.
thanks for any advice
Vinceb is offline   Reply With Quote
Old 01-04-2011, 04:34 PM   #13
swidd
Drives: Yaris HB
Jee. Yes, just oil changes.
And take it somewhere cheaper!
Oil & Filter: $26 mobile 1 synthetic, $8 some filter, $15 some quick lube to change it for you.
Cabin Air filter: as long as its there, it doesn't have to be clean.
Manual Trans Fluid: wow, at least you got something cheap!
Coolant: $22 for a gallon, and extremely easy to do yourself over a drainage hole.
swidd is offline   Reply With Quote
Old 01-06-2011, 12:29 AM   #14
Revsson
I'm calling the EPA!
Old 01-06-2011, 11:00 AM   #15
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I am hopeful swidd was joking.(?) Dumping coolant into the environment is NOT a good idea. Ethylene Glycol is extremely toxic and a relatively small amount can kill a child or small animal who may be attracted by it's sweetness. Who knows where it will end up. Collect it and recycle it. It doesn't take much more effort to be responsible.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 01-06-2011, 11:34 AM   #16
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Originally Posted by R2D2 View Post
...Ethylene Glycol is extremely toxic and a relatively small amount can kill a child or small animal who may be attracted by it's sweetness. ...
I lost a pet cat as a result of my dad not covering up the antifreeze he drained into an oil catch in our driveway. He went into the house to get something and the cat must have smelled it and lapped some up while he was inside.
Dead cat.
Old 02-07-2011, 01:47 AM   #17
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
Timing belt
I don't see anywhere the timing belt being mentionned
do we have a timing chain in them little engines , or is that something
not mentionned anywhere for interval replacement ????
.. found an old subject on the web ..
"Power is from the 1NZ-FE 1.5-liter four-cylinder engine familiar from the Scions and the Prius. Here is makes 106 horsepower at 6000 rpm, with 103 lb-ft of torque at 4200 rpm, and drives the front wheels through either a five-speed manual or four-speed automatic transmission. Like most current Toyota engines, it is an aluminum alloy unit with dual overhead cams, four valves per cylinder, VVT-i variable valve timing, coil-on-plug direct ignition, and electronic throttle control. There is a timing chain, not a belt, for lower maintenance. "
I guess that answeres my question , timing chain , HOURRRAAAAA !!!
Kazimodo is offline   Reply With Quote
Old 02-07-2011, 07:35 AM   #18
Kal-El
Kal-El's Avatar
Yup, timing chain likely good for the life of the car.
Saves about $800-$900 every 100K.
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
