Old 12-13-2006, 01:13 AM   #1
Have you tried Rain-X or any other similar products that help water flow off the windshield easier? I'm quite sure it will help with this.
Old 12-13-2006, 09:25 AM   #2
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
I first noticed the hazing problem/issue when I applied Rain-X to the shield back in June or July.
I figure by this time the Rain-X must worn off, so that it is likely no longer the source of this issue.
Originally Posted by punch View Post
I believe its both, the windshield and the wipers, i think you have a thin film of oil ( air pollution) on your window, try cleaning the window with a good glass cleaner...also are you using defog, with heat? if so it may be drying the window. you should also have the selector to outside air...also consult the owners manual for other tips
I will try that, thanks, taking a good glass cleaner to the outside of my windshield.
I over find I need to use defog to speed the un-hazing process along (it clears up faster with defog (even on days when its not cold out so you wouldnt think Id need to be using defog at all).
Yes, the selector is left almost always set to outside air. And I wish I had an owners manual... *somehow* a month after I got the car I somehow lost it and have never found it. And new manuals are still on back order at Toyota, so I haven't been able to purchase a new one either.
Can anyone provide me tips for cleaning my wipers, in case that is part of the problem as well. Just use my regular micro-fibre cloth? What kind of solution should I spray them with when cleaning? soap and water? some kind of store-bought product?
Again, thanks for any assistance.
Jem
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 12-13-2006, 12:31 PM   #3
60 Somethings
Old Folks
60 Somethings's Avatar
Drives: 2007 Yaris LB, 2006 4Runner V8
Have been fighting this problem for the last 10 yrs.
Looks like it's a thin film of road grease as was stated.
Who has the SOLUTION!!! Would love to find an easy one.
We are the proud owners YARI -
He's a loaded Silver LB with ATTITUDE!
60 Somethings is offline   Reply With Quote
Old 12-13-2006, 01:38 PM   #4
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
If you clean (and I mean Really Clean) the outside of your winshild with Windex It should fix it.
Nutzoids is offline   Reply With Quote
Old 12-13-2006, 01:55 PM   #5
Jem_hadar
MORDSITH
Jem_hadar's Avatar
I hope so. I plan to clean it QUITE WELL and thoroughly tonight if I can get the time, and then next time I am driving and its wet out, hopefully Ill notice the issue has gone away. *crosses fingers*
In Collingwood it doesnt bother me so much, its when Im driving (especially at night!) on the 400 or 404, or when I am right downtown Toronto that this reduced visibility and effect really bothers me, bc its a distraction I really dont need somewhat impairing my driving experience.
Old 12-13-2006, 06:12 PM   #6
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Did you went thru the carwash ? waxing cycle put that on the windshield (even without waxing cycle you get that because the water is recycled). it will last a few days
cleaning wipers: I have no idea whether this is some protective layer or just dirt, but if you try putting Rain-X on a white cloth and wipe the rubber with it, you'll be amazed as the cloth will turn black again and again
hystria is offline   Reply With Quote
quick window tinting question...?? static808 Cosmetic Modifications (Exterior/Interior) 8 10-16-2006 08:49 AM
