Old 11-24-2009, 03:34 AM   #19
hare
Drives: VITZ RS1500
I am sorry for misunderstand,what I mean is the 1zz injector on NCP13,I have a NCP13 with blitz supercharger but need bigger injector,do you know if it will fit???thanks a lots.
Is your question about the AEM kit? If so, I would not know. The box hax been sitting in my garage for the past few months waiting for my lazy ass to install it.
I don't see why it would not fit. From what I've read by other posters, the biggest problem is finding room to install the water bottle.
hare is offline   Reply With Quote
Old 11-24-2009, 11:03 AM   #20
ask 1NZYARIS1 if the injectors for the 1.3L are the same as the 1.5L. I believe they are, in which case you can "upgrade" to the 1ZZ injectors.
Old 11-24-2009, 02:22 PM   #21
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The 1ZZ injectors will work great on your car.
Actually the NCP13 has the same 1.5 1NZ-FE
His is a first gen Yaris TS/RS
Old 11-25-2009, 09:28 AM   #22
hare
Drives: VITZ RS1500
thanks for confirm,I will try to take off mine one to double confirm before I buy the new injector,hopefully will sort out the problem of my car and go quicker in the track,cheers
Old 11-26-2009, 12:06 PM   #23
Giupo
Drives: Yaris
the 1zzfe injectors are about 290cc, the oem 1nzfe injectors are about 210cc, I council you the 2zzge injectors these are 350cc and are good still for future upgrade.
the 1zzfe e 2zzge injectors are bolt on for 1nzfe engine.
Giupo is offline   Reply With Quote
Old 12-09-2009, 11:22 AM   #24
cdydjded
Drives: Yaris LB Turbo
LtNoogie:The next picture is of the blue 1zz injectors (PN 23250-0D050) going into the fuel rail to replace the grey tC injectors. The stock injectors are PN 23250-21040. There's got to be a way find the specs on these two injectors.
I look up injectors from a warehouse I buy from & it shows the 1ZZ injector to be a part of 23250-0D040. According to this web site http://injectorrx.com/densotf.html, the 23250-0D040 is a 255cc/24lb injector. I cant seem to find the specs for the 23250-0D050. Are you sure on the part #?
Old 01-04-2010, 05:21 AM   #25
hare
Drives: VITZ RS1500
the one I saw in ebay also have a different number at the back as well,I guess is the year of the be made?I think as soon as it's the same colour should be the right one?
Old 06-10-2013, 05:50 PM   #26
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Thread necro!
Just want to add my two bits: the green 1ZZ injectors I scrounged from a 2003 Vibe (255cc) are working much better than stock. No "rich condition" codes at idle yet, can't confirm WOT readings until I get my AEM AFR gauge installed but my Scangauge II drops to 12.0 AFR as soon as I enter boost. As far as I can tell, that's all the lower it reads.
Here's verification of the stats from an injection cleaning service (witchhunter.com)
Here's a shot of them snugged under the fuel rail:
And here's a shot of the amputated valve cover nub:
Old 06-12-2013, 09:19 AM   #27
jetblast
Drives: Gen 1 XB
Thanks for digging this thread up. My TC injectors are green also. Gonna have to check the part numbers. Thanks!
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 06-12-2013, 12:34 PM   #28
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I got a set of 23250-0D040 on ebay from a Celica. Work great with the Blitz.
Old 08-20-2015, 09:48 PM   #29
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Question Check Engine Light - Lean Code
So what would help me with this code?
Will these work as far as the 1zz goes?
http://www.ebay.com/itm/New-Denso-23...d1650b&vxp=mtr
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
Old 08-24-2015, 11:26 AM   #30
AzianCuz
conundrum562
AzianCuz's Avatar
Question 1ZZ Fuel Injectors
put in my 1zz injectors yesterday. no CEL, runs great. my AFR at WOT during open loop before the 1zz injectors was about 12.4-5 now it's 11.4-5. *I was getting the 12.4-5 without the 1zz injectors because I switched back to my Stock airbox instead of my aFe intake that i had. When I was running with the stock injectors and afe intake, i had a 13.4-5 AFR @ WOT during open loop.
But now I am running the 1zz injectors and switched back to my aFe intake, and now am running the 11.4-5 AFR @ WOT openloop.
So I went ahead and ordered these, per the post:
Hopefully my lean code goes away? You guys have any other solutions for this lean code P0171?
Old 08-25-2015, 09:59 PM   #31
AzianCuz
conundrum562
AzianCuz's Avatar
I've upgraded my injectors to the 1ZZ PN 23250-0D050 and it makes the car idle very good, less shaking and more throttle response. As far as the check engine light lean code goes, I haven't seen it come on yet. Hopefully it doesn't anymore.
Old 08-25-2015, 10:02 PM   #32
CrankyOldMan
I get it once in a while, under WOT for extended periods of time. I also have a CAI and a non-standard MAF intake section, so it's possible the ECU is just getting confused. Or was it the MAF out of range? I dunno, I get P0101, P0170 and P0171 pretty regularly. My ScangaugeII clears that right up.
Old 08-25-2015, 10:09 PM   #33
AzianCuz
conundrum562
AzianCuz's Avatar
Nice well hopefully I don't get codes anymore, It's annoying. Without the 1ZZ I kept getting P0171 after cleaning the MAF sensor.
Old 08-26-2015, 06:32 AM   #34
CrankyOldMan
If your MAF is clean, P0171 means an intake leak. I've had problems with the bolts on the end of the plenum coming loose and causing vacuum leak at idle and pressure leaks under boost. A bit of loc-tite red did the trick. You should also do a vapor check--get a can of carb or brake cleaner and spray a little of it along the intake components. If the engine surges, you have a leak in that spot. If you need new gaskets for the Blitz, I may have a spare set around here somewhere.
Old 08-26-2015, 08:23 AM   #35
AzianCuz
conundrum562
AzianCuz's Avatar
No more CEL after the 1ZZ confirmed. Cranky is it worth it to dyno? Or could I just leave it as it and run it as my daily. I am going leave boost at medium settings and drive it normally.
Old 08-26-2015, 09:35 AM   #36
KTS
KTS's Avatar
Drives: Vitz RS
Glad you got it sorted out.
KTS is offline   Reply With Quote
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
