Old 11-28-2009, 09:20 PM   #1
b_hickman11
Drives: 08 Sedan
Originally Posted by Fazulka View Post
I read through that thread, but i don't think that is the problem we had. Others have had the same problem i did because of the missing filter. I unclogged it, drained the water, put a cabin air filter in and haven't messed with it since. I installed it during the spring, now at least 6 months later we have not had a problem with smell since we got the carpet to stop smelling.
So you changed about 4 or 5 different varriables(including the filter) and you got better results....And you are claiming better results solely on the filter install? I have had a cabin air filter since day 1 in my 2007 Yaris and the AC smells pretty bad. I have a cabin air filter in my 2008 Yaris and it doesn't smell at all. Therefore it sounds like your smell was being caused by one of the other few things you changed not on the fact that you added a filter.
b_hickman11 is offline   Reply With Quote
Old 12-09-2009, 01:10 PM   #2
Fazulka
Drives: 2007 Yaris 4dr Sedan Base
True I did fix the smell by changing several variables, but the filter was the root problem. No filter let debris in, debris clogged drain, excess stagnant water got smelly and was splashing around in car. There may be other ac smells, but it mine was caused by the filter. The smells are not taken away by the filter, clogs are prevented by the filter.
Fazulka is offline   Reply With Quote
Old 12-09-2009, 09:46 PM   #3
b_hickman11
Drives: 08 Sedan
Awwww I see now. Guess you must live in an extra dusty/debris area. Don't think Toyota would consider making the cabin air filter standard based on a few area's conidition.
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Cabin Air Filter xairmech DIY / Maintenance / Service 6 04-22-2009 12:28 PM
HEPA filter for cabin air lh59 DIY / Maintenance / Service 2 03-23-2009 09:17 PM
Installed Cabin A/C Filter caveatipse DIY / Maintenance / Service 11 09-13-2007 01:07 AM
