Old 11-29-2009, 01:15 PM   #1
toad
toad's Avatar
Drives: street-legal go-kart
someone earlier mentioned the filter is just as important as the oil. i just changed the wife's yaris with pennzoil platinum 5w-30 and a mobil1 'extended performance' filter. i know the platinum is good stuff, but are the mobil1 filters any good(i would hope so as the filter retailed for 12.99 at autozone, but i got a deal for 5 quarts pp and mobil1 filter for 27.99)? i'm hoping this combination will get me 7500-10,000 miles as i'm already out of warranty(i normally change every 5000-6000, but i figure the fancy filter and full synthetic will help extend that).
toad is offline   Reply With Quote
Old 11-29-2009, 07:52 PM   #2
06silveryaris
Drives: 2006 yaris
Mobil 1 filters are very good quality and so are the pure one from purelator. You should be just fine with that oci
06silveryaris is offline   Reply With Quote
Old 11-30-2009, 02:18 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I have 85K miles on my Yaris (07). I use Amsoil with Toyota air and oil filters ( Sparks Toyota sells a case of 10 oil filters for $30 ). I change my oil @ 10K intervals and filters at 5K intervals . I have been doing 10k oil changes since 30k . My other Yaris (09) has 8k miles . It was driven off the lot with Amsoil . The 09 will also see 10k oil change intervals .
Old 12-03-2009, 06:37 PM   #4
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Amsoil once a year
I use AMSOIL 5w30 w/AMSOIL filter EAo09 and change it once a year. I do not go over 20k and will change at 20k if I do.
Go4th is offline   Reply With Quote
Old 12-03-2009, 07:35 PM   #5
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
The EAO09 filter is no longer recommended for extended use in our cars due to the Toyota engine issue that came up with the 1.8 liters. The filter should be changed at OEM intervals. Amsoil does recommend the MANN filter for use up to 7500 miles if used with Amsoil.
Ask your Amsoil dealer for more info or e-mail me and I'll send the TSB.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
