#30 |
The OEM jack is only for lifting from the sides, one wheel at a time. The front and rear jack points are for lifting the car with a floor jack. Because of the position of the rear point, a 20" lift jack is required to get the rear tires off of the ground. The front lift point is more than 30" under the car, so an extended reach jack is required to lift from that point, unless you put it on ramps first to give the necessary clearance to be able to pump the jack.
| Is MP3 AUX Jack Grounded properly? | iseraph7 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 07-16-2009 05:51 PM |
| Factory AUX Jack | ojo | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 06-06-2007 09:41 PM |
| aux jack | SurfBabe900 | New YARIS Purchase Forum | 12 | 06-04-2007 02:06 PM |
| New Floor Jack | blacksan | Off-topic / Other Cars / Everything else Discussions | 5 | 05-16-2007 02:32 PM |
| Positions for Jack Stands? | bigsky2 | DIY / Maintenance / Service | 2 | 11-03-2006 01:24 AM |
