Apexing Egg!!
the misinformation is strong in this thread.
i will say again, i ran those wheels with the same set up everyone else here uses: Tanabe DF210's, shocks, and rear bar. i use the HTS, but that doesnt effect spring rate and rub, they are dampers! the rear fit perfect with no rub, no additional camber. the front fit with the maximum camber with the small bolts from toyota, and that is still only -1.5*, which is STILL very little camber. that much camber has in no way effected the tire wear on my car. i also ran a 195/55/15. things may be a little different with a 205/50/15, and certainly with a 205/55/15. they work, with the set up everyone here uses. yes you need some front camber, no you cant run huge ass tires. i feel pretty sure that the average 205/50/15 would fit just fine, but if not, then buy the best tire money can buy right now, the 195/55/15 star specs!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#2 | |
Shut your fricken suck!!!
Yes! Yes! Yes! I was able to run 205/50/15's on a +40 offset and I had no prob(except for being super low to the ground). I also did well with the 195/55's(which I'm rocking once again). When I moved up to the 205/55's, I rubbed in the front. Even with the camber at -2, I still had rubbing. That size of a tire is just to wide for anything less than +42, especially on a liftback that is dropped more that 1.7 inches.
| JDM Wheels and some track wheels/tires | jdmekcivic | Items for Sale by private party | 10 | 09-08-2009 12:27 PM |
| Found a NEW set of Wedsport/C-One wheels | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-16-2009 07:47 PM |
| Another set of new wheels for the Toaster | Black Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 55 | 01-12-2009 12:13 PM |
| I want to buy a set of alloy wheels | yv1650c | Items for Sale by private party | 2 | 08-21-2007 12:23 PM |
