Old 12-03-2009, 02:40 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
From what Ive seen on oil boards, 90 percent of people getting their oil tested misinterpret or make bad assumptions with the test results. All said, an economical practice (using a good long life synthetic like Total Quartz or Motul X-max or redline) would be to: just do a 2x /year oil change in december and april in cold climates. Make sure you have a good filter on there too - nothing too fine sieve. This would not apply to short trippers , you need more frequent OCi. Me, I dont like mid grade PAO synthetics, PAO are not inherently good lubricants - though they are good cold flow fluids. They will oxidise and thicken over long drain intervals. Amsoil (?) and M1 Ep are examples of PAO syns. The toyota 0w-20 Idemitsu syntetic is a fine oil if you are not afraid of 20wt like me - My car gets flogged too hard, IMO , for 20wt but I'm willing to be proved wrong on this. Note: I am not aware of the 1nzfe being spec'd for 0w-20 oils and I dont know why, given toyota spec the 1nzfe for 5w-20.
Old 12-03-2009, 08:24 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
You're correct-it's not speced for 0W-20 and also correct that it makes no sense in light of allowed 5W-20 use. The BIOSYN I'm currently running has the highest HTHS of any 20 wt I've seen so no worries.
R2
-The Fitful One
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
