Old 12-07-2009, 03:02 PM   #1
m3ga_band_g33k
Drives: '08 Toyota Yaris Hatchback
My horn quit - not the fuse.
Hello everyone!
I have a 2008 Yaris Hatchback and the horn has more or less quit working. 95% of the time it doesn't work, maybe once or twice every other week or so I can make it sound, and even then it sounds really weak and kind of peters out after a few seconds if I hold the horn down. The fuse is fine, what else should I check? I was in an accident back in February that may have knocked something loose, the horn quit about a month after this accident.
Any ideas would be great.
Thanks!
m3ga_band_g33k is offline   Reply With Quote
Old 12-07-2009, 05:08 PM   #2
Check the horn itself and the one wire connector going to it. It is mounted to the front of the top radiator support bracket. If you pop the plastic clips for the front bumper, you can pull it back enough to get at the horn, without completely removing the bumper.
Old 12-07-2009, 08:11 PM   #3
b_hickman11
Drives: 08 Sedan
Also check the D3(I think) connector underneath your steering wheel.
b_hickman11 is offline   Reply With Quote
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 09:35 AM
HELP! SRS light won't go off, horn doesn't work kudzu71 DIY / Maintenance / Service 11 08-18-2009 06:12 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 01:07 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-19-2009 12:28 AM
Horn broken, watch for finger RogueYaris General Yaris / Vitz Discussion 11 06-26-2007 11:16 PM
