Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 12-08-2009, 01:02 AM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Originally Posted by Sir A.Y. Atoyot View Post
The Allen key hole isn't any kind of bolt. The pulley is held on by the nut on the shaft. Nobody I know uses the Allen hole for anything - just use an impact wrench to remove or replace the pulley.
I wrote it all wrong, there is no allen hole, the axle itself ends in a 10 mm bolt... which is now nice and round after I tried to loosen the nut...
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline
Old 12-08-2009, 03:01 PM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Looking at the alternator on my 2008 5-door, I see what you mean - the rotor shaft ends in a hex that you can fit a wrench to. However, the whole assembly is still held together by a nut. You can still remove the nut with an impact wrench. Too bad about the hex, but it really isn't necessary.
Sir A.Y. Atoyot is offline
solar trickle charger and alternator wingdood Fuel Economy Forum 33 10-12-2009 04:02 PM
H.O. Alternator question goku87 In Car Entertainment + Electronics (audio / video / alarm) 52 06-30-2009 10:14 AM
Alternator intermittently charging after 323,000 miles. trini_per4mance General Yaris / Vitz Discussion 39 04-21-2009 01:08 AM
lightweight alternator buddyjim Performance Modifications 10 02-03-2009 05:31 AM
More Alternator ?'s!!! plushDJ DIY / Maintenance / Service 0 05-06-2006 02:10 PM
