Old 12-08-2009, 08:35 AM   #1
jonismyname
Drives: 08 liftback 5spd
there's a mountain of info lurking in these waters, you just gotta stick your head in to see it.
ill throw a few things out there that aren't my opinion (my opinion, go at least 3k on factory oil then do what you like):
-factory oil is break in oil and needs to be run 5k
-factory breaks in motor before they ship it, you can do whatever you want as soon as you get it
-you should change your oil as soon as you get it home, then again at 500 miles, then again at 3k. (just because its 1500cc doesn't mean its a motorcycle motor...)
jonismyname is offline   Reply With Quote
Old 12-08-2009, 10:12 AM   #2
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
I switched to Amsoil at 2000 miles.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 12-08-2009, 12:49 PM   #3
RedRide
RedRide's Avatar
*Factory "break in oil" is rarely used anymore in any car these days .
* Engines are not broken in at the factory. Engines are first run only after final car assemby when all engine support parts are installed.
Having said that .... With modern machine tools, critical engine parts are now made more precise and the break in procedures of old are no loger nessary for the most part. Just take it easy for the first 2k or so.
However, personally, I like to change oil initially at about 2k miles as during this period, you have the most (nessary) break in wear and there are microscopic metalic particles suspended in the oil that should be removed.
Finally, synthetic is not some mysterious miracle oil that needs special conditions etc and can be used at most any time after break in. It can also be mixed with "dyno" oil in any proportions.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
