Old 12-08-2009, 11:33 AM   #1
CasuaL
CasuaL's Avatar
Drives: 2008 Yaris Hatchback
Switching to reverse problem
hi,
i have a problem. almost every time i switch to reverse, there is this sound coming from under the hood like all the gears are getting messed up. don't know if you understand me, but it is almost the same sound as if you try to switch gear while driving and you didn't press the clutch all the way to the ground. i don't know what it is, but it's not very nice to hear.
does it ever happen to you guys?
CasuaL is offline   Reply With Quote
Old 12-08-2009, 12:23 PM   #2
RedRide
RedRide's Avatar
Keep in mind that the reverse gear is not synchronised. So, a a bit of finess and common sense is prudent when accessing reverse.
BTW, most other cars do no have synchros in reverse gear either.
Old 12-08-2009, 01:23 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
+1
Try shifting to 2nd before you shift to reverse and you'll never hear grinding again.
Old 12-10-2009, 02:17 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
+1 every manual car Ive driven for the most part was a little sticky when going into reverse. And Ive driven a lot of manual cars probably more than most. Used to work at a dealer having to move around cars and park them on the lot.
Old 12-08-2009, 01:02 PM   #5
tomato
tomato's Avatar
Originally Posted by CasuaL View Post
hi,
I think I understand.
No it doesn't happen anymore, maybe once or twice when I first got the car and wasn't used to it yet.
On my Yaris, you *really* have to have your left foot *all the way* down when you switch gears (even a millimeter or two can make a difference) and when you switch to reverse you have to push a little harder than the other gears and it's not as comfortable and intuitive. It should go in smoothly though. You'll get used to it.
Old 12-08-2009, 01:56 PM   #6
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
It's normal, almost all manual transmissions cars make some amount of noise going into reverse.
As others have suggested, shift to 2nd gear, then reverse.
Old 12-09-2009, 12:07 PM   #7
CasuaL
CasuaL's Avatar
ok, i'll try it, thanks guys...
Old 12-10-2009, 11:21 AM   #8
CasuaL
CasuaL's Avatar
you were right! before switching to reverse i go to 2nd gear and it goes smooth as silk... thanks for the tip...
Old 12-10-2009, 11:32 AM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i vote on 2nd gear before reverse...actually any forward gears before reverse will do.. and ull be grindless for the life of ur clutch!!
Old 12-11-2009, 10:31 AM   #10
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Just double clutch and you should be ok!
Old 12-11-2009, 12:26 PM   #11
RedRide
RedRide's Avatar
That works also.
Old 12-11-2009, 01:55 PM   #12
DerFlosser
DerFlosser's Avatar
Drives: Yaris
try putting a cold Getrag into reverse. It'll make your Yaris feel like butter.
As many state....perfectly normal for a manual gearbox and double clutching or forward gear selection will help.
DerFlosser is offline   Reply With Quote
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 06:32 AM
Switching to synthetic oil problem curtqn DIY / Maintenance / Service 45 02-19-2015 02:39 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Reverse gear crunch Frankd1 DIY / Maintenance / Service 5 04-13-2009 12:43 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
