My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
When does the Northeast switch over to summer gas?
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
HA Ha ha
We don't have summer and winter blends any more. All the gas is cut with ethanol all year round. The alcohol just cuts your milage and raises the oil company profits. The environmental benefit just doesn't make this a good proposition. Flex fuel vehicles are as big a joke as HEVs. doc |
![]() ![]() Drives: 2008 Sedan White Join Date: Oct 2008
Don't feel too bad, I was doing 45 46 in the summer. Winter fuel dropped it down to 40 41. Then I put my studded tires on and last two times at the pump I'm at 37 and 38. Mostly driving the same. Good grip in the snow and ice tho.
Reluctantly Crouched...
Must be some other factor. Nothing about winter fuel should improve mileage, and every other car I've owned suffers on winter fuel. I know Dallas is an EPA zone that gets "cleaner" buring gas, so maybe the winter version is "normal."
got to figure in taking longer to reach operating temperature during cold than those warmer days . Thus using more gas with higher idle .
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
I was just going to make a thread on this! My last fuel mileage calc with rotella diesel 10w-30 motor oil in the sump was 33.6mpg. Then I just changed over to 3 qts M1 AFE 0w-30 and the rest M1 5w-20. The car now has a real noisy cold start and run for 15mins. I just refilled the tank a 1/2 hour ago and I got 32.4! I dont like this synthetic oil! I was getting 38mpg last winter running PYB 5w-30 dino. I wonder, too, if the exhaust is getting plugged? There is a TSB on this for the 3 door for the exhaust plugging and a free replacemnt exhaust system if you have fumes (sulphur odour) in the car.
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
i don't know if it's the gas or else , but my yaris mpg is pretty bad during the winter time ....26mpg
![]() I believe partly because of the remote start engine that running around 10 minutes each time , twice a day ....and Im still using the same tires setup + full header back exhaust .... oh well Im driving less than 10 miles everyday to work anyway
Half a Bubble Off Plumb
It's the remote start. I hate to let a car idle to warm up, though I've done it to defrost windows. All the fuel that's burned at idle is wasted, it increases noxious exhaust emissions, and that's when the engine really builds up sludgy glop in the oil from condensed moisture and partly burned fuel. In the old days it'd often cause cars to trail blue smoke from gummy oil making the piston rings stick in their grooves. Still might, but newer oils suspend sludge better. Much better to drive away and let the engine warm up more quickly.
der Zeck
i am very surprised no one has pointed out the fact
stock tires: Circumference: 74.58 in 1894.3 mm Revs per Mile: 876.1 your oversized tires: Circumference: 77.31 in 1963.6 mm Revs per Mile: 845.1 so that means every 100 miles your car thinks you drive, you actually drive 96.5miles so you are getting worse mileage than you think
Yo! YarisHilton, what happened to your beard?!?
![]() And Black Yaris, I have checked my speedo against my GPS, and it is accurate. I wondered about this when I initially got the car because I have 17" wheels on it; but either the dealership calibrated the speedo or the larger tires reduced the speedo error (which happened on my Jeep when I went from 29" tires to 31" ones. And since I've had my Yaris for over a year old, that could not be a factor in the decreased mileage. Cheers! M2 |
Is now a Corolla S Owner
Oversize tires will cause the odometer to register fewer miles than actually driven, not more miles. So, you would be getting better mileage than you think, not worse.
Think of it as the car traveling further for each rotation of the bigger tire because of its greater circumference. By the way, who was the roundest knight at the Round Table? Sir Cumference, of course! |
Thanks YarisOwnersDad, I needed a chuckle this morning!
And ya look younger being "clean cut," Mr Hilton! Happy New Year to you all! Cheers! M2 |
I miss the beard!
Took a bit of getting used to for me, too.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Is anyone elses yaris idling a bit higher even when it's fully warmed up, as compared to when it's a hot summer day and the idle of the car is very low when it's warmed up? Seems like my Yaris keeps a higher idle when it's cold out as compared to a summer day, even after it's fully warmed. Not a HIGH idle, just higher than if it's hot outside.
Mine does for a good while after the "COOL" light goes out, but it's not actually fully warmed up. After a good long drive, it falls back to a hair over 600 RPM. In a cooler place (it's 19 F here this morning), it might not drop back to normal idle speed.
If you have the air control set to defrost or defrost/floor, the air conditioning will cycle. That will raise the idle.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Do you get about 4 MPG less during winter ? | paraganek | Fuel Economy Forum | 24 | 05-18-2009 09:52 AM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
