![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
I filled up this morning at one of my normal spots and what did I see on the pump.....
10% ethanol That must be why I am down to 39MPG on average. That and more city driving has made me lose about 3-5MPG.
Its all about the MPG's !! |
#2 | |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Half a Bubble Off Plumb
Yes, at most of the stations where I live it's all E15. There are some with just E10 but not many.
Yeah, I am also in San Antonio and I can't find gas without ethanol anywhere...
Cheers! M2 |
![]() ![]() ![]() Drives: 2008 Sedan A/T Silver Join Date: Nov 2008
Why do I get terrible gas mileage in the winter?
I know every car suffers MPG drops in the winter. But why is that? Is it because of the winter blend type of fuel being used? Or does an engine use more gas to stay warmer during the coler months? I drive my Yaris the same gentle way I do in the winter as I do during the warm spring days (with the exception of snow storms, etc.) I never see my RPM's going so much higher to suggest using more fuel. Does the engine use more fuel, even though it is keeping the RPM's at the same levels? Or is RPM just not a good indicator of how much gas is being used?
Winter blend fuel, you use the heater (electric more), and in my case I have 4 snows mounted........ not too mention there is more resistance on the roads with slush and snow...... longer warm-ups.....
I usually average 36-38 in the winter and during real bad weather as low as 32
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
I can see the winter blend fuel, that's what I think is affecting the most. I didn't know the heater requires that much more energy. During the spring and summer, I have my fans / AC blowing all the time. I usually don't warm up the car. Just turn on, shift to drive, and go. I can understand the slush and snow, but for the most part, here in NJ, when it snows, by the next day most roads are cleared. Hmm......
Well, my "cool" light takes longer to turn off in the winter so the engine is not up to temperature as fast. The tires do not expand and heat up in the winter either.
Your engine likes warm and hot air to be brought into it from the intake. The hotter it is outside, the better mpg's you will get. I recorded my best mpg on a day it was 105+ degrees outside.
#11 | |
I can't wait for those days to return! |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
So in this case Hot Air is Good!
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Precisely. This is why many of us hypermilers block our grilles in the cold months, and why some also set up DIY warm air intakes.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#14 | |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
doc |
winter is good for nothing
Here in Edmonton We get good week long cold snaps of -20C.
I never let my car Idle long, and have never had to plug it in even at -35C... It started with a few more turnovers. My question would be: Would it help with millage to have a warmer engine bay with temperatures of -20 and lower? I find my water Temp to be around 85C when its that cold. |
#18 | |
doc |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Do you get about 4 MPG less during winter ? | paraganek | Fuel Economy Forum | 24 | 05-18-2009 09:52 AM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
