Old 12-10-2009, 01:36 PM   #1
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
Quicker Decelertaion
I'm not sure if there is already a thread on this (i had no luck finding one) but when you will notice when the car is sitting still or in gear that when you rev the engine the deceleration is very slow compared to most cars. What are some step you can take to change that?
Old 12-10-2009, 03:23 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
I think its possible due to the drive by wire system electronic throttle. When you snap it on a conventional system the cable snaps open the butterfly and the spring quickly snaps it shut if you take your foot immediately off the gas.
On our system its controlled by a computer and electronic motor. Could be the motor can not react as quickly within a split second and gradually closes back down the butterfly.
Old 12-10-2009, 07:45 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
A lightened flywheel will solve that problem , but will create others
Old 12-10-2009, 09:02 PM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
like stalling when you flip it into neutral. my car does this all the time now!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-10-2009, 09:47 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
really? that stinks.
Colin Chapman disciple
Old 12-10-2009, 10:26 PM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
its not a big deal. if rolling, throw it back in gear and if stopped, just start it haha
Old 12-11-2009, 12:09 AM   #7
i had fidanza in my xrs and never had a stalling problem.....6.5lbs vs 13lb stock....so super light too
but lightweight pulleys and flywheel will help the engine rev up and down more quickly
Old 12-11-2009, 12:29 AM   #8
BrazdonW
Are these the only possibilities?
Old 12-11-2009, 12:51 AM   #9
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Hack the signal to the throttle body?
2006 Red Blitzed RS 5-door
Old 12-11-2009, 01:04 AM   #10
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Actually, it would be possible to use a 1ZZ throttle body. My idle went up 200 rpms when I installed mine (and hasn't gone away), which would help.
Old 12-11-2009, 02:16 PM   #11
BrazdonW
i have a corolla tb is that what you mean?
the deceleration didnt change when i swapped it.
Old 12-11-2009, 02:17 PM   #12
BrazdonW
maybe i should do more pulleys?
i have the lightweight crank pulley
would changing the others really help?
Old 12-12-2009, 11:17 PM   #13
kngrsll
Apexing Egg!!
kngrsll's Avatar
why do you want to make the engine stop spinning faster??
the only reason i can think of would be because that means it spins more easily while accelerating? thats kind of a backwords way to look at an improvement in throttle response though.
to improve throttle response, in general there are two things you can do. lighten the parts that rotate (ie pulleys, flywheel, remove things like AC) or improve the flow (individual throttle bodies, header). i think timing has a small influence, but its probably minimal.
so if you improve throttle response, you will improve your engine slowing down thing, also increasing your ability to stall the car lol
Old 12-13-2009, 01:49 PM   #14
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
More engine brake would help with throttle steering but I don't know if thats what BrazdonW had in mind.
thepoche is offline   Reply With Quote
Old 12-13-2009, 01:56 PM   #15
BrazdonW
It is more of preference thing than it is a performance thing
i like when it snaps back fast because it is what i'm used to
the other cars i have owned have all snapped back much quicker
and its not as if every car i have owned has been a performance car (geo metro, dodge neon, vw gti mkII)
as an econo car i know it will have some quirks but this is just one i don't like
id like to fix it somehow :)
Old 12-28-2009, 11:08 PM   #16
jonismyname
Drives: 08 liftback 5spd
hmm. friction brake on the serp belt? if anyone (other than ctscott, he's busy making yargauges!) has the ability to read the signal to the solenoid that controls the throttle body it coud at least be confirmed it's a bastard child of fancy programming and our econobox.
another option is following in garms footsteps---fancy gas pedals and cable system!
standalone ecu?
i'd say it's in the software...
jonismyname is offline   Reply With Quote
Old 12-30-2009, 03:17 PM   #17
MUSKOKA800
MUSKOKA800's Avatar
I noticed this back in the day when emission controlled vehicles became the normal and was told that a slower/controlled RPM drop reduced pollution. My guess is that todays cars rev down slowly for the same reason.
Old 12-30-2009, 03:22 PM   #18
No problem at all with stalling and a lightweight flywheel here. (and that includes before I added FI). Don't let these guys warn you off of that idea. Excellent way to open up throttle response, both directions.
BP Ultimate means engine quicker warm-up? lh59 DIY / Maintenance / Service 45 12-18-2008 03:37 AM
