Old 12-16-2006, 01:07 AM   #1
03Z33
03Z33's Avatar
Drives: TCR10
Originally Posted by static808 View Post
wow, i took a quick peek at your garage and it does look quite nice. how has the camber change affected your handling and tire wear?? i'd never think that someone could pull off those kinds of wheel numbers with a yaris...
--B
I haven't posted any pics of these wheels yet... I'm waiting for some different coilovers so that I can lower the front more first. Camber won't affect your tire wear too much, it's toe that kills tires. If you drive aggressively and corner a lot like I do, the negative camber will actually help increase tire life. I run -2 deg front and -2 deg rear (shimmed) with 0 toe all around. It makes the car feel 100% better (handles like a go kart!)
For OP, you may want to run 195/55/15 tires if you don't plan to lower the car a lot, this will help fill in the fender gap a bit more, and will be easier to stretch since they have more sidewall.
03Z33 is offline   Reply With Quote
Old 12-18-2006, 10:51 AM   #2
NotAMini
Drives: Dealer Strip Model
nice. Thanks for the info.
NotAMini is offline   Reply With Quote
Old 12-24-2006, 10:34 PM   #3
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Too much - Camber will destroy tires very quickly depending on your driving habits.
BUT you are correct toe will mutilate tires even faster.
DTM_Yaris is offline   Reply With Quote
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Ideal Offset? 15x7 ET42 Wheels TRD_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-18-2006 04:12 AM
15x8 with a 0 offset birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-10-2006 05:40 AM
max width and offset? Fat Felixxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-08-2006 03:43 PM
Max offset riceboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-01-2006 09:57 PM
