![]() Drives: yaris, venza Join Date: Nov 2009
i've got the single low beam bulbs, so no DRL, but i did noticed when i turn the lights switch one notch, just to turn off the head lights, but with the rear and corner lights still on, the HID will flicker for afew more seconds before it finally turns completely off. would replacing those bulbs with bi-xenon bulbs sovlve this problem? with bi-xenon bulbs, would i get DRL ? |
#2 | |
The Beautification of Car
If you do have DRL = Day Time Running Light, you will need to disconnect it someway or somehow, either a fuse, a plug or something. HID don't like DRL My gf got a Aveo, and she got h4 bulb with DRL, so to be able to install HID, i need to remove the DRL plug under her steering wheel to disable DRL, and then when you install HID you will loose DRL. Or as other said you can wire it to highbeam and use your highbeam as HID, but if you don't know then it's will be a mess. |
| XenithXenon HID Conversion Kit | CorSport | CorSport | 0 | 09-03-2009 05:11 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
