why do you want to make the engine stop spinning faster??
the only reason i can think of would be because that means it spins more easily while accelerating? thats kind of a backwords way to look at an improvement in throttle response though.
to improve throttle response, in general there are two things you can do. lighten the parts that rotate (ie pulleys, flywheel, remove things like AC) or improve the flow (individual throttle bodies, header). i think timing has a small influence, but its probably minimal.
so if you improve throttle response, you will improve your engine slowing down thing, also increasing your ability to stall the car lol
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
